Socket Size
Old Oct 6, 2009 | 09:47 AM
Yeti1775's Avatar
Yeti1775
Socket Size
Ok what's the socket size for the rail fuel filter to replace it?
Crawled under and I know I don't have a size big enough for it.
Wife doesn't mind me buying tools though to all for us to do our own work.
Thanks.
Eta: 2003 F350 6.0L FX4 Extend Cab Longbed
Last edited by Yeti1775; Oct 6, 2009 at 09:50 AM. Reason: ETA - Truck info cause i'm an idgit forgetting it first go around.
Old Oct 6, 2009 | 09:54 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
36 millimeter
Old Oct 6, 2009 | 09:58 AM
Yeti1775's Avatar
Yeti1775
Thanks.
Was fustrating when changing the oil and fuel filters out all out the other day coming up with that one.
Now the question is will she let me go into Tractor Supply unsupervised on the way home tonight.
Old Oct 6, 2009 | 10:10 AM
bismic's Avatar
bismic
A "Lisle" brand socket at an auto parts store is MUCH cheaper. It works better on 4x4's also since it is not as long.
Old Oct 6, 2009 | 10:29 AM
origcharger's Avatar
origcharger
Absolutely! And the other plus is its 3/8" drive rather than 1/2" found on a normal socket of that size, so you can use ratchets and extensions that work better in confined areas.
Old Oct 6, 2009 | 11:08 AM
Thor80's Avatar
Thor80
Here's a reference that might help, includes socket sizes and torque specs.
http://www.dieselfiltersonline.com/D...ence-Guide.pdf
-Torsten
