Sponsored by: Real Truck
Driveline Wind up??
Old Oct 6, 2009 | 11:02 PM
EXv10's Avatar
EXv10
I would consult another dealer. Also, I would think when you turn on a curve while in 4wd on dry pavement you could experience "driveline windup" because the front and rear wheels loose their sychronization.
Old Oct 7, 2009 | 07:01 PM
Frozen001's Avatar
Frozen001
Exactly I could understand if I was turning I may experience "driveline windup", but on a straight away, I can't believe it...
Old Oct 7, 2009 | 08:07 PM
EXv10's Avatar
EXv10
Maybe your gears are different front to rear or tire diameter is different. The out of synch condition would build up as you drive because there is 0 tolerance for it. You just can't drive a truck in 4wd on pavement. You would have to drive perfectly straight and maintain exact rpm syncro front to rear, so the dealer was probably right. All it takes is tires low on air etc, etc etc.
Old Oct 23, 2009 | 08:28 AM
Frozen001's Avatar
Frozen001
As an update... I took the truck back in last week because the 4wd would intermittantly not lock the front hubs. They found the passenger side knuckle seal was leaking vacuum. The replace the all the seals on the passengers side. Everything is fine know, no grinding or bang. This incidentally is the second time that seal has been replaced..
thillmaine
Apr 18, 2016 11:36 AM
sportfuryjoe
Oct 18, 2015 08:45 PM
DISLFVR
20
Sep 21, 2015 02:15 PM
fe8u
Jan 7, 2011 05:26 AM
Nichonj
Sep 9, 2009 09:03 AM
