Sponsored by: Real Truck
'08+ Reverse Sensor. Need Housing.
Old Oct 4, 2009 | 08:17 PM
GTXgp's Avatar
GTXgp
Question '08+ Reverse Sensor. Need Housing.
I upgraded my '06 rear bumper to an '08+ bumper. The swap was very easy, however, the "housing" (what the sensor themselves snap in to) for the reverse sensors is different and my new bumper only has the holes, but no housing.
Does anyone know the P/N or a good source to get the housings?
Thanks,
Adam
Old Oct 4, 2009 | 08:40 PM
bayou barataria's Avatar
bayou barataria
They don't have a housing. they just kind of have a little sleeve that probably comes with the sensor itself.
Old Oct 4, 2009 | 10:50 PM
GTXgp's Avatar
GTXgp
If I remove the sensor from the BACK side of the bumper, there is a plastic housingthat is still on the bumper. Sleeve, housing, collar, whatever you want to call it. You remove this piece from the FRONT. That is the piece that I need, and I'm hoping that it is available seperately from the sensor since I'll need all 4.
Old Oct 7, 2009 | 07:20 AM
GTXgp's Avatar
GTXgp
For anyone doing a search... if you run in to this same problem and do the swap or need to replace this piece for some reason, it IS available seperately. Ford calls it a "retainer", here are the part numbers:
RH Outer: 7C3Z-15K861-A
LH Outer: 7C3Z-15K861-B
RH Inner: 7C3Z-15K861-C
LH Inner: 7C3Z-15K861-D
Hope this helps someone in the future
Adam
Romanova
Nov 20, 2015 08:12 AM
stv1991
Jun 6, 2015 07:14 AM
stv1991
Nov 21, 2014 09:23 PM
adam68
Oct 17, 2014 04:53 PM
creator
Oct 17, 2012 11:25 PM
