Reverse sensor question...
Old Nov 12, 2015 | 09:55 PM
Romanova's Avatar
Romanova
Searched and didn't find the answer. I replaced my bumper with a 08 bumper and now my sensors don't work. It's possible I have the harness flipped on the wrong side.
Does anyone know if the sensor plugs have to correspond to a specific sensor?
Old Nov 13, 2015 | 12:42 AM
pirate4x4_camo's Avatar
pirate4x4_camo
I am going to guess you bent or damaged a pin on the connector taking them apart or putting them back together. they are tiny little buggers.
Set parking brake, Turn the key on engine off, put in reverse. Go put your ear next to each sensor and listen for the clicking, The one not clicking is your issue.
Old Nov 19, 2015 | 04:38 PM
Romanova's Avatar
Romanova
SOLVED!
Each sensor has a specific plug. Based on the 2005 wiring diagram that worked for my 2004, it goes as follows:
LH Outer: BN/PK, WH/LG, DG/YE
LH Inner: BN/PK, DG/WH, DG/YE
RH Outer: BN/PK, DB/YE, DG/YE
RH Inner: BN/PK, WH/LB, DG/YE
I got it mixed up when swapping the harness over from the old bumper. Thankfully it is long enough that I was able to swap it back to the proper orientation without having to disconnect the license plate lights. All four plugs were difficult to seat in all the way till the plug clears the plastic tab on the sensor. One was so bad that I ended up pulling the white bumper in the plug so it would snap into place. For that one, I wrapped it in electrical tape with some dielectric grease to keep it weather proof.
Hopefully this helps someone in the future.
Old Nov 20, 2015 | 08:12 AM
Greenscobie86's Avatar
Greenscobie86
I plan on doing the swap soon so this will definitely be helpful to me. Kudos!
alwayne
2009 - 2014 F150
Aug 10, 2017 05:07 PM
Romanova
Nov 20, 2015 05:20 AM
Pyancey
Jan 16, 2013 09:08 PM
puller45
Apr 23, 2010 07:22 PM
bahyde
Nov 13, 2007 08:17 PM
