Oil pressure sensor 1/8 straight thread
Old Oct 4, 2009 | 06:47 PM
dt444e's Avatar
dt444e
I got an Autometer oil sending unit I would like to hook up. It is 1/8"NPT. The hole in the top of the HPOP that holds the stock oil pressure sensor is 1/8" straight thread w/an o-ring, and I would like to keep it so it works as stock then I'm getting rid of my Banks six gun(cause it sucks) and then putting an oil pressure gauge in its spots. However how can I use the stock one then tie in too put the autometer tee'd in to use the stock one?
Old Oct 4, 2009 | 09:48 PM
Izzy351's Avatar
Izzy351
It gets installed on the back of the block on a port near the oil filter housing. It's near the coolant drain, but further back.
EDIT: Found a pic. It's the big brass colored sending unit with a single wire attached.
baker1983
Jul 11, 2012 07:13 AM
79Ford4x4
Mar 23, 2010 08:59 PM
dt444e
Oct 6, 2009 03:38 PM
MustangMatt96GT
Dec 7, 2008 03:22 PM
MSC
Jul 9, 2004 10:26 PM
