Injector driver module?????
Old Oct 6, 2009 | 05:47 PM
F350-6's Avatar
F350-6
The quarter shim locks the harness connector to the pass thru connector on the valve cover. Depending on exactly what you broke, you'll either need a new harness or a new valve cover gasket.
It is possible to just buy a new connector for the wiring harness, but I would not trust the repair connection under the valve covers.
Old Oct 6, 2009 | 11:33 PM
natew's Avatar
natew
I just shelled out $89 for the UVCH because I broke that clip which wasn't even the #@$$!^% problem. Did the $89.50 cent mod while I was there. Put the truck back together and the code P1316 came up and still running crappy. Does that mean it may be other side UVCH clip is loose? What else could it be?
2002f250xlt
19
Feb 15, 2012 07:29 PM
fixnair
Feb 20, 2011 08:22 PM
Firefighter 1406
23
Apr 25, 2009 05:55 PM
Catchup
44
Jan 16, 2009 05:02 PM
c00nhunterjoe
Jan 5, 2009 07:06 PM
