oil filter wrench
Old Oct 5, 2009 | 01:13 AM
Kwikkordead's Avatar
Kwikkordead
The best filter wrench can be found at NAPA.
I forget the part number right now, but a picture from F350-6's gallery will give all the detail that you need.
https://www.ford-trucks.com/user_gal...205034&width=2
Old Oct 5, 2009 | 01:22 AM
mechelement's Avatar
mechelement
I went into NAPA looking for that filter wrench because I heard good things about it from this forum and they said it didn't exist. They hadn't a clue about it. I finally gave up and used the one I posted previously. It's never let me down and it was a fraction of the price of that NAPA filter wrench. NAPA in this area sucks.
Old Oct 5, 2009 | 10:54 AM
husker's Avatar
husker
I use a filter wrench that looks like it has a "bicycle" chain on it. I purchase it when I first got the truck and couldn't get the filter off with the old screw driver through the filter trick. I don't remember the brand, but it works great.
I always loosen the filter enough that I can get it off by hand before punching a hole in the filter to drain the oil and before pulling the plug on the pan on the outside chance that the darn thing would be stuck so I can't get it off and need to get some help or have to drive it somewhere. That way I don't have a disabled vehicle with the oil filter stuck that is shredded to pieces.
Old Oct 5, 2009 | 11:49 AM
superduty4x4's Avatar
superduty4x4
I have one from Napa (probably the same one as mechelement) and it works great. It can also be used to remove the fuel bowl lid
Old Oct 5, 2009 | 12:05 PM
riverrat41's Avatar
riverrat41
I use these.Made by Channel lock.Work well on Ford and others.
Old Oct 5, 2009 | 02:58 PM
mudmaker's Avatar
mudmaker
I have several different size band type, but usually just use the channel locks like Barry has pictured here. I got them when my biggest band clamp was not big enough for a hyd. filter we had on a truck. They are great for getting off all sizes of filters.
Old Oct 5, 2009 | 06:07 PM
bunklash's Avatar
bunklash
If somebody tells me how to post a photo here, I'll show you a picture of the absolute very best working, filter wrench ever. Trouble is, I don't remember where I bought it, and it doesn't fit larger size filters.
I promise it's one some (maybe most) of you have never seen.
Old Oct 5, 2009 | 08:05 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
I use a "three legged" adjustable wrench from Sears -
Craftsman Universal Oil Filter Wrench, Auto-Adjustable
it cost less than $20 too, fits the filters for our trucks and just about everything else smaller
Old Oct 5, 2009 | 08:12 PM
Orezona's Avatar
Orezona
IMO, if you need a wrench to get it off, it is too damn tight. I tighten mine by hand and take it off by hand. Back in the day, 6 years ago, I'd hand tighten it, then go the extra turn with the wrench. It would be a BUGGER to get off. That is how I discovered the screwdriver wrench method.
Seriously, put it on by hand. Give it a snug turn by dry non-slick hands. It won't leak. Then you can poke it with a screwdriver on the bottom to drain the oil out. Then put a 1/2 gallon zip-loc bag over it and yes, remove it by hand with the bag over it. No wrenches period.
Old Oct 7, 2009 | 06:43 AM
hdman6's Avatar
hdman6
Smile
thanks for all the responses, I did get it off using the "drive a large screwdriver through it method" even with the screwdriver through it it was a bear. I had to drive the screwdriver through it almost 4 tiimes to get it off because I could only turn it so far whithout hitting something. I did finally put the new one on hand tight with a extra 1/4 - 1/3 turn by hand to tighten it snug. It hasnt leaked. The dealer was doing these changes while I had the coupon book for oil change , rotate tires and lube. Believe it or not, it was a bargin at the time because it was before oil went throught he roof. So I guess i made out. But now i am doing it all. Anyway thanks for the replies. Jeff
Old Oct 7, 2009 | 07:00 AM
5280's Avatar
5280
This style works great. I have a couple of different sizes in my tool box, I have yet to find a canister filter they will not take care of.
Old Oct 7, 2009 | 07:41 AM
riverrat41's Avatar
riverrat41
I do not normally need them on my Ford but on the wife's Dodge I have to use them everytime just to break it loose and I always put it on hand tight with a 1.4 turn?????Anyway...these Channel Locks are very handy and MADE IN USA
Old Oct 7, 2009 | 08:40 AM
  #28
Kwikkordead
When I get to work today, I'll get the part number off of it and post back.
Old Oct 7, 2009 | 10:10 AM
  #29
Kwikkordead
It is a KD-2320
GOOGLE SEARCH
johnkn
2015 + Expedition & Navigator
Jun 8, 2015 06:06 AM
Todd Fuller
15
Oct 28, 2014 12:26 PM
myexpo02
18
Jan 16, 2008 10:00 AM
poppie
Sep 10, 2007 06:45 PM
RedTaurus94
19
Dec 18, 2003 09:26 PM
