Oil filter wrench
Old Dec 15, 2003 | 09:27 AM
RedTaurus94's Avatar
RedTaurus94
Oil filter wrench
What oil filter removal device does everyone use? After struggling a few times to get my FL-1995 off and on, I bought a strap-type wrench, but it slips too much to suit me. Surely there is something better. I wonder what the "professional Ford mechanics" use. Ford probably makes a special wrench, knowing them.........
Old Dec 15, 2003 | 09:29 AM
Shake-N-Bake's Avatar
Shake-N-Bake
I've been able to unscrew the filter with my hands (so far). But I have a strap wrench in my toolbox just in case.
Old Dec 15, 2003 | 09:34 AM
jschira's Avatar
jschira
I use one of those wrenches that looks like a big slip-joint pliers.
It gets everything off. Most auto parts stores have them for <$10.
Foneguy's Avatar
Foneguy
Strap Wrench. Works great and cheap
Old Dec 15, 2003 | 09:38 AM
eckart's Avatar
eckart
I spin it off by hand. Do you grease your seal before you put the new filter on? Sure makes them easier to get off.
Old Dec 15, 2003 | 11:14 AM
AggiePSD's Avatar
AggiePSD
I've got two wrenches. One on the end of each arm!
Seriously though, I put mine on as tight as I want by hand, and they always come off by hand too. I've added length to a regular strap filter wrench, and channel-lock pliers always come through in pinch.
Old Dec 15, 2003 | 08:06 PM
believer45's Avatar
believer45
Snap-On, Mac and such carry filter wrenches like the ones you can get anywhere for car filters (a metal strap that tightens on the filter the harder you pull on the handle) that are larger for truck filters. I have a Snap-On, you should be able to get one from NAPA or any truck parts supply store in your area.
Dave / Believer45
Old Dec 16, 2003 | 06:30 PM
Quadzilla's Avatar
Quadzilla
I got a strap wrench at the local auto parts store for about $7. It was referred to as a "Truck filter" wrench, and is large enough to fit the larger filters. Another use for it: it's a handy way to grip and rotate a section of 4" exhaust pipe.
Old Dec 16, 2003 | 09:04 PM
johnsdiesel's Avatar
johnsdiesel
Those of you who are doing it only by hand must not have it on that tight. My Ford service manual says to tighten it by hand and then give it an additional 1.5-2 turns with a wrench.
If you have a strap wrench and don't want to by a new tool, use a piece of sandpaper between the wrench and the filter with the grit on the filter. I'm assuming you have a rubber strap wrench and not the chain type strap wrench.
Old Dec 16, 2003 | 09:05 PM
Jlower's Avatar
Jlower
Strap Wrench! Works great on the fuel filter too.
Old Dec 16, 2003 | 09:09 PM
Peter94's Avatar
Peter94
Theres actually like a "socket type" that i use, mainly cause theres no way i'd be able to get a strap wrench on the filter, its like a big socket, and it fits on the bottom of the filter, and attaches to a 3/8 drive socket wrench, works great every time, except for when you get some oddball filter that doesnt have the groves on the end
Old Dec 17, 2003 | 09:16 AM
shorebird's Avatar
shorebird
Nylon strap attached to a square tube 1/2"id that fits onto my 1/2" rachet.
Old Dec 17, 2003 | 09:35 AM
rmilchman's Avatar
rmilchman
I use K&N filters, on the bottom of them is a 1 inch nut.
Old Dec 17, 2003 | 09:56 AM
02PSD4ME's Avatar
02PSD4ME
Strap Wrench.
Old Dec 18, 2003 | 08:49 AM
johnsdiesel
Those of you who are only putting the filter on by hand must not be tightening it enough. My Ford service manual says to tighten it by hand and then give it 1.5-2 additional turns.
If you don't want to buy a new wrench use a piece of sandpaper between the strap and the filter with the grit on the filter side. I'm assuming you're using a rubber strap wrench and not the chain type for the filter.
