Horn?
Old Oct 3, 2009 | 10:40 PM
Stephen67's Avatar
Stephen67
Horn?
So I think I am missing a piece other than the outside cover horn button on my steering column. Problem is I have no idea what goes to a complete horn assembly on the column as I've never seen on.
Any idea what I'm missing or is it just the button and the problem is possibly else where?
Thanks
Old Oct 3, 2009 | 10:58 PM
BlueOvalRage's Avatar
BlueOvalRage
It looks to me like the only thing that you're missing beside the button is the spring. It's the round piece with the prongs pointed towards the center at the bottom of this pic:
It's $2.95 from Mac's part#7RC-14479. The horn button is $50.95 part#B6C-3627-A. That's with a red center. It looks like there are a couple others that will fit, too. You'll have to decide. I don't speak more than a few words of 1953-1956. If you short between the bullet in the very center and the rest of the metal ring underneath it, the horn should honk if everything else is working.
Old Oct 4, 2009 | 12:01 AM
Stephen67's Avatar
Stephen67
Ah ok, thanks. I was trying to get it to go off, I'll have to try that when its not so late at night, ha.
thanks again
Old Oct 4, 2009 | 09:12 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Bonus Built horn, similar I'm sure
Old Oct 4, 2009 | 12:36 PM
Julies Cool F1's Avatar
Julies Cool F1
Once they are all assembled, th espring will usually end up staying lodged in the horn button when it is removed.
Just about everyone sells the buttons and the springs. If you want to make the horn sound all you need to do it touch the very center stud to any part of the cap surrounding it (I'd clean up that cap a bit or spend the $5 on a new one). It's very hard to see but they are electrically insulated from one another by a small insulator on the top of the wire - the center stud is actually the end of the horn wire - and it's hot - all the time.
Be careful because the horn - even though powered through a relay to handle the high amperage draw will still pull a few amps at the botton. If you touch those, they are going to spark at you and th ehorn will sound (providing th ehorn and relay are good), and I guarantee eventhoughyouare expecting the spark and sound, you're gonna jump. And if something inadvertantly falls across the two, it will eventually weld itself together. That is is the horn doesn't wake the dead first.
Old Oct 4, 2009 | 12:58 PM
Stephen67's Avatar
Stephen67
Very interesting, thanks ^_^
Anyone got a shot of the horn button from the underside? I'm debating to make one (I'm a blacksmith)
Old Oct 4, 2009 | 03:50 PM
Julies Cool F1
Here ya go! and as long as I had the button off I took a nice clean picture of my new contact assembly. Hope this helps:
PS. You can buy a new reproduction button for $45 at C&G. I'm sure the other resto places have them too:
https://secure435.hostgator.com/~dlv...g=45&t=330&tn=
Old Oct 4, 2009 | 04:25 PM
Stephen67's Avatar
Stephen67
Thanks! Thats exactly what I needed
Stephen67
Mar 19, 2012 09:45 AM
Stephen67
Mar 15, 2012 11:43 PM
Stephen67
16
Jan 4, 2012 09:20 PM
Stephen67
38
Jul 12, 2010 12:04 AM
Stephen67
Oct 3, 2009 08:56 PM
