fuel problems
Old Oct 5, 2009 | 11:45 PM
rbaker6336's Avatar
rbaker6336
If the heater shorts out and blows the fuse,think it's on the same system as IDM,any ways it won't run with that fuse blown
Old Oct 6, 2009 | 12:18 AM
krejci.mike's Avatar
krejci.mike
Originally Posted by Riffraff Performance
Any chance you broke the fuel bowl heater when you changed your filter? Maybe blew the fuse?
When I was looking at it just now I think I might have done something to it. The top where the metal pin comes out, the plastic looks broken... should I replace it or is that not necessary?
Old Oct 6, 2009 | 01:07 PM
krejci.mike
bump. it still will not start
Old Oct 6, 2009 | 01:26 PM
jbwingman's Avatar
jbwingman
Make sure no leaks in fuel- can you hear the fuel pump running with just the key on- do not start-Check fuel bowl, did anything get into the fuel uptake.
If no good-suggest go to just answer.com -cost you about 5-10 bucks.
jb
Mr. Badger
Jan 12, 2011 06:44 PM
DemonRace6
Jul 14, 2009 11:10 AM
74hiboy
16
Jul 7, 2007 05:18 PM
mytruckiscool
Aug 15, 2005 11:13 PM
