Build backyard shooting range
Old Oct 3, 2009 | 12:40 PM
lew52's Avatar
lew52
I want to build a place to shoot in my yard . Would a dirt berm be the best ?? Any ideas ??
Old Oct 3, 2009 | 03:57 PM
Ford_Six's Avatar
Ford_Six
A wall of railroad ties backed by dirt works well, but most areas don't allow shooting within 400yds of a residence without specific permission from the homeowner. This could pose a problem if you have anyone within 1/4 mile, and I wouldn't set it up in a direction where there was anyone within a mile.
Going to the range isn't that expensive, and you don't have to worry about maintenance and upkeep there.
Old Oct 3, 2009 | 05:47 PM
BillC's Avatar
BillC
This might be a dumb question you are out of city limits are'nt you?. Plus you might want to check with you insurance company.
Old Oct 3, 2009 | 06:05 PM
00BlueOvalRanger's Avatar
00BlueOvalRanger
Very good points.
IF you want to build a shooting range, knowing your locale and the local laws would be the starting point.
Now, with that said, I recommend excavating a range, and using dirt berms, at least 10 feet high, and at least 3 feet thick.
(Don't have a clue as to WHAT you want to shoot on your range!)
Check with the NRA. They have a great range development department, and have some really great ideas and planners. (Just a thought. . . )
Old Oct 4, 2009 | 04:00 AM
lew52's Avatar
lew52
Yeah i have heard about the railroad tie system, that sounds good . The excavating sounds good to but i live in florida , so i can't dig to much with out hitting water . Yes its out of the city limits , five acers , nearest house about a 1/2 mile away . The direction we would shoot theres nothing for miles . Shooting 22s , 45 , AR -15s...Thanks for the help ! ... Lew
Old Oct 4, 2009 | 01:03 PM
*2fords*'s Avatar
*2fords*
When I still had my property, I bought 12 1500lb hay bales real cheap and stacked them 2 high for a bullet catcher. Worked great and last several years. I image, since you don't get snow down there, they may last alot longer.
Old Oct 4, 2009 | 09:17 PM
GLR's Avatar
GLR
I made up one with 1/4 " steel plate, about 30x30" in the front. Tapering down to nothing over 24" in the back. This way the bullets would be deflected downwards to the bottom, which was filled with sand. Being lazy I also rigged up a clothes line pulley outfit to set and retrieve the target.
Old Oct 4, 2009 | 09:32 PM
Old93junk's Avatar
Old93junk
Lew, I would shy away from shooting that AR-15 on that home made range, especially in flat country like that........Those 5.56s will CARRY!.....even .22lrs I would be careful about. Neighbors even a half mile away could get pretty upset about ricochets........Pistol calibers, ...blast away!
Old Oct 4, 2009 | 11:13 PM
85e150's Avatar
85e150
I would want a fail-proof backstop. Plenty high, with a mechanical way of limiting the angle of fire. A high-powered rifle at a 45 degree angle could be well out to 2 miles or better.
At the AZ machine gun shoot, according to the video playing at Turner's one day, they clear SEVEN miles....
What is the access to the property behind the range? Kids wander in there to harvest their pot plants or sniff flowers?
Someone catches a bullet and it's all downhill from there, so keep that in mind.
Double check the zoning and building codes too:
http://www.heraldnet.com/article/200...916/0/COMM0601
Old Oct 5, 2009 | 04:30 AM
lew52's Avatar
lew52
Ok thanks for the info . I think i will just shoot at the range for now . I will check it out more , i don't need any trouble , Thanks ... Lew
cigarxtc
34
Apr 30, 2014 11:24 AM
FordTruckGuySTX
19
Oct 10, 2005 07:02 AM
Marc150
36
Oct 7, 2004 03:59 PM
cheese4420
Oct 22, 2003 09:28 PM
BuiltToughF250
Mar 11, 2003 04:52 PM
