Sponsored by: Auxito
Check engine light after muffler install
Old Oct 2, 2009 | 05:55 PM
blue76's Avatar
blue76
I have a 98 f150 4.6L 4x4 with 166k. after I put a new muffler on and some new exhaust pipe, the check engine light came on, if I disconnect the battery it will go away when i restart, until I rev over about 3000 rpm, then it comes on again. I took it to advance auto and had them scan the code, and they said it was something like "auxillary emmission control" or something like that, Does anyone know what this means? or how I can fix it?
Old Oct 2, 2009 | 06:06 PM
n5926g's Avatar
n5926g
I would suggest you look at the downstream 02 sensors. Check for damaged wiring to these,and general condition of the sensors. Pull them,and inspect if you have the proper socket.
Old Oct 3, 2009 | 01:09 AM
KhanTyranitar's Avatar
KhanTyranitar
Some mufflers and pipe combinations can theoretically interfere with the EGR system. What is the actual code, the description you gave seems awfully generic.
Old Oct 3, 2009 | 03:55 PM
blue76's Avatar
blue76
The code I get is P1409
Old Oct 3, 2009 | 04:00 PM
n5926g's Avatar
n5926g
EGR Vac solenoid circuit...check the harness for anything that could be disconnected,or dis-lodged.
Kapusta
15
Dec 6, 2015 01:39 PM
cjben
Sep 17, 2015 04:02 PM
yankeez76
Nov 29, 2011 12:33 AM
rvx290
Exhaust Systems
Dec 17, 2009 10:03 AM
mtfrdlvr
Exhaust Systems
Dec 4, 2007 02:29 AM
