Start problem
Old Oct 7, 2009 | 12:27 AM
conger's Avatar
conger
Originally Posted by themetalmaster
Took it to the dealership yesterday, got a call today and they said injectors 5,6,7,8 are bad.
Do they all go bad together at the same time?
they checked the FICM first, and said it was good.
Can the injectors cause it to be hard to start, but as soon as it warms up it runs fine?
The 6.0's are really sensitive as to what oil goes in them. Cheap oil or the wrong grade will cause injector troubles. That's not to say that your not doing your maintenance correctly, so please don't take that the wrong way....But if you bought the truck used as many of us do. How did the last guy treat it? Did he do his maintenance or just drive it hard until he was done with it and trade it off. If you haven't checked out the 6.0 tech folder yet....It's good reading.
Old Oct 7, 2009 | 06:53 AM
bismic's Avatar
bismic
These injectors are the back two on each side of the engine. It is possible that low fuel pressure damaged these four injectors first. The 6.0L injectors are VERY sensitive to low fuel pressure.
Have you ever:
run out of fuel?
found either of your fuel filters plugged when you changed them?
got a tank of bad fuel?
go past 15k miles before changing the fuel filters?
Also - you should only use Motorcraft, Racor, or International fuel filters. The others may let water through, deform, or blind off early, etc.
Old Oct 9, 2009 | 10:13 PM
themetalmaster's Avatar
themetalmaster
4 New injectors #5,6,7,8 a flash update and everything is fine but my butt!
Old Oct 9, 2009 | 11:06 PM
bismic's Avatar
bismic
Have you ever:
run out of fuel?
Many people have over 133k on their original injectors. There might be a cause for these failures .... that could still be there.
Old Oct 9, 2009 | 11:39 PM
themetalmaster
Thanks everyone, especially bismic & npccpartsman.
May your trucks run strong and long!
Old Oct 10, 2009 | 05:57 AM
npccpartsman's Avatar
npccpartsman
Did you have them check the fuel pressure while it was there?? I'd be really interested/concerned what it is because of all your back injectors failing.
Old Oct 10, 2009 | 06:23 PM
conger's Avatar
conger
I'd be interested in your your fuel pressure as well. Those injectors aren't cheap. I might be adding a fuel pressure gauge next summer. Too friggin cold out to do it now. npccpartsman & bismic, reps for both you guys. Great info.
Old Oct 10, 2009 | 09:50 PM
TreeTech's Avatar
TreeTech
FICM not Injectors
I had the run on 4 cyl symptons when cold for the last 6mo, i just new my injectors where going south at a 149k, until last Sat it would not run at all. I ruled out hpop and got a Brand New FICM off Ebay for $150 and the nice seller was a International Tech and took it to his work and flashed it for me.. Now my truck runs like it should Cold or not..
Big props to this guy for selling a New unit at a great deal and the free programming..
Ericasands
Apr 2, 2014 06:38 PM
goat man
Nov 15, 2013 06:35 AM
MNbandit
Aug 7, 2010 09:16 AM
big island
General Diesel Discussion
May 16, 2008 02:44 AM
trailrider74
Feb 4, 2007 11:38 AM
