Offroad & 4x4
Mud Racing Gear Selection
Old Oct 2, 2009 | 02:38 PM
wvbogger's Avatar
wvbogger
I wanted to see if anyone might have some suggestions for my truck. I currently run a 466 solid roller high compression motor it makes power from 3000 to 6500 rpm. I estimate it would make around 550hp. I run a c6 with a 3500 stall and a 205 transfer. I have 4.88 gears with lockers front and rear. I run 37" boggers. My question is what gear should I run and should it be in high range or low. I have been running low 2nd and going to 3rd if needed. I was thinking I should be maybe running high 1st and going to second if needed. Any suggestions would be appreciated. The mud I run in is usually 18-24" deep. My last run was a 3.81 on a 150' pit and I just thought a different gear approach might get me a little more. We just dont have many races for the trial and error approach. Thanks
Old Oct 3, 2009 | 02:42 AM
Bender99's Avatar
Bender99
Was there any mud in that pit? 3.81 is haulin! That seems pretty fast for running that kinda motor in low range with those gears and tires.
Old Oct 3, 2009 | 07:55 AM
351slug's Avatar
351slug
I have never had that kind of power before but I think you have enough to pull Hi Range. My friend with a built Ranger with 460 stroker runs Hi Range with like 100 mph wheel speed. But I think he is also using NOS, lots of torque. Good Luck
doc54321
2004 - 2008 F150
18
Sep 23, 2015 12:33 AM
wvbogger
Offroad & 4x4
Nov 4, 2010 04:58 PM
Thomsen
Offroad & 4x4
Aug 4, 2007 07:21 PM
wyldstallyn73
Oct 18, 2004 12:23 AM
nolanc2
Offroad & 4x4
Feb 26, 2003 07:11 AM
