35's on 2wd f250 with Leveling kit? please advise!!
A friend of mine gave me a fairly new set of Pro Comp tires 35 x 12.5 R18 my truck is a 03 f250 psd lariat 2WD with just a 2" leveling kit, do I have any chance with this tires? is there an specific off set type of wheel that can help me? your advise will be very much appreciated.
Well I already lifted the front with a 2 inch leveling kit that I bought on ebay and yes my camber is off, they installed a camber kit at the alignment shop but I've noticed uneven wear on the outside of my stock tires, and if you stand in front of it you can see it. I'm thinking getting rid of the coil spacers back to stock, sell the Pro Comps and get me a set of 33's.
Can you post pictures of your truck? do you have coil spacers or full suspension lift? I've contacted a company in Utah that custom makes lift kits, they will quote me a full suspension lift to avoid the alignment problem, nothing big just enough to fit the 35's w/out rubbing.
Ok, this is the quote I got:
all for $1,019 plus installation wich is around $480-$600
Should I throw this cash on a 2WD?
Pro Comp Susp. Lift Kit; Ref.; Frnt/Rear ES3000 Shock; Black; 6 in. Frnt/3 in. Rr
Lift; Incl. Frnt Kit/Rr Block w/UBolt Kit/Frnt Coil Springs/Rr Add-A-Leaf;
35x12.5 in. Max Tire Size; 193lbs
Pro Comp Carrier Bearing Drop; 5lbs
Pro Comp Pitman Arm; For 4 in. Drop; 6 lbs
Shipping includedLift; Incl. Frnt Kit/Rr Block w/UBolt Kit/Frnt Coil Springs/Rr Add-A-Leaf;
I would like to see your truck if possible just to have an idea how it looks, and by the way I'm selling a set of 16 inch aluminum wheels with 36's mickey thompson tires with great thread tire size is 375 75 R16. this tires are like 15 inches wide and came out from a lifted 2001 f350 srw.
robs01f250
09-09-2010 12:47 PM
