Slave, master or bent fork?????
Old Sep 30, 2009 | 04:07 PM
quality1construction's Avatar
I came out from work today, pushed the clutch in, fired it up and it would not go into any gear, I ended up shutting it off, putting it in 2nd and going, it does not want to go into any gear. But if I shift it without the clutch (hitting shift points) its good, no slips, no problems. I replaced both the master and slave about 70k ago. Something feels different in the clutch pedal, like its to easy, doing nothing. Any help would be greatly appreciated.
Old Sep 30, 2009 | 04:17 PM
IDPisan's Avatar
IDPisan
Typically when the master/slave go out your clutch pedal will go to the floor and stay there. If it is coming back up but not all the way I would say your clutch fork may have given up the ghost.
Old Sep 30, 2009 | 05:39 PM
Do they make an improved design? Is this a normal problem? Dealer Item?
Old Sep 30, 2009 | 05:48 PM
robs01f250's Avatar
robs01f250
does it grind when you press the clutch?
Old Sep 30, 2009 | 07:00 PM
Yes it does make a noise when the clutch pedal is pushed in. The pedal is way too easy to push now, I checked to ensure the rod is still connected from pedal to master cylinder, and fluid is full no signs of any leaks, but no that I think of it, it's been funny shifting into some gears for a little while now.
Old Sep 30, 2009 | 07:10 PM
Bigcat350's Avatar
Bigcat350
Sounds like the slave to me. But I would replace both slave/master are they still under warranty. I just went through this my pedal stayed on the floor so I replaced the slave but that wasn't the problem so then I replaced the master and all is good now. Both at Auto Zone with a life time warranty for about $110 IIRC
Old Sep 30, 2009 | 07:14 PM
F350-6's Avatar
F350-6
Pull the slave out of the bell housing and use a screwdriver to feel where the fork is. If it's bent, you should be able to figure out it's too far away from where the slave rod sits.
Old Sep 30, 2009 | 07:15 PM
SpringerPop's Avatar
SpringerPop
Yes. Yes. Yes.
Lemmee dig up an old thread from Kwikkorded......
Though there isn't a part number redily available without further research, look here:
https://www.ford-trucks.com/forums/4...omplished.html
Pop
Old Sep 30, 2009 | 07:19 PM
My pedal does not stay at the floor, it sits at the normal position, but moves way to easy.
Old Sep 30, 2009 | 07:33 PM
Bigcat350's Avatar
Bigcat350
Can you hear a hissing noise when you mash it in?
Old Sep 30, 2009 | 07:40 PM
I believe so yes.
Old Sep 30, 2009 | 07:57 PM
Bigcat350's Avatar
Bigcat350
Dion I could mash my pedal in by hand and hear a hissing sound like fluid leaking past the seals in the master and thats what my problem was but I am glad I changed the slave also it made it shift easier. I had only had my new clutch in a couple weeks when it happened. We had just got back home from RRE
Old Sep 30, 2009 | 08:20 PM
I have no fluid leak, the level is full, and both master and slave appear dry.
Old Sep 30, 2009 | 09:02 PM
Bigcat350's Avatar
Bigcat350
Yea mine did not leak at all on the outside.
Old Sep 30, 2009 | 09:05 PM
I will check into it more tomorrow and update with what I find. Thanks for all the help!
