Slave, master or bent fork?????
Old Sep 30, 2009 | 09:25 PM
SpringerPop's Avatar
SpringerPop
If it turns out to be a bent fork, be sure to get the updated one, pictured in the thread noted above.
Pop
Old Oct 1, 2009 | 08:45 PM
quality1construction's Avatar
Well its not the clutch master or slave cylinder, changed those today. I was told by a gentleman today that it sounds like the pilot bushing is gone. Could that be the cause?
Old Oct 1, 2009 | 09:41 PM
SpringerPop
The pilot bushing COULD be gone, also, but that's not the root cause of this problem. It's looking more and more like that fork is bent. Wasn't that your initial thinking in Post #3 above.
When you're in there to get this fixed, be sure to replace that pilot bushing with one of the new Kevlar ones anyway, even if it doesn't look or feel bad. The new design is just that much better.
The new-designed fork is, too.
Pop
Old Oct 1, 2009 | 10:37 PM
eckart's Avatar
eckart
yup I've got the new fork in mine. Sounds like you'll be getting one to.
Old Oct 9, 2009 | 08:15 PM
I dropped the tranny this evening, what a task. The fork does appear to be bent and looks twisted. I am thinking I should add a kevlar pilot bushing while its apart thoughts?
Old Oct 9, 2009 | 08:21 PM
F350-6's Avatar
F350-6
I'd add the kevlar in a hearbeat as long as the tranny is out. If the disc, pressure plate, throw out bearing (cheap looking part that you might consider swapping too, but that's just a personal bias over how cheap it looks) look good, then the kevlar bushing and updated fork is all you should need.
I'd also check your up pipes about 4 times before the tranny goes back in. If you have even the slightest sign of a leak, the swap will be 100 times easier with the tranny out of the way.
Old Oct 10, 2009 | 12:36 AM
SpringerPop
Originally Posted by quality1construction
thoughts?
I gave you mine in Post #18 above.
'Nuff said.....
Pop
Old Oct 10, 2009 | 01:00 AM
eckart's Avatar
eckart
If theres a fair bit miles on the clutch and you can afford it put a clutch in it while its apart. Just that much longer till it all has to comes apart again
Old Oct 10, 2009 | 06:54 AM
Yougotthehit's Avatar
Yougotthehit
If its making a hissing noise when its in and not when its out your throw out bearing is going bad. Im on my 3rd freakin one in a matter of this summer. Granite I put about 10k on a month but it shouldnt be doing that.
Old Oct 10, 2009 | 10:13 AM
SpringerPop
I would also put in a new throw-out (release) bearing while in there.
Pop
Old Oct 10, 2009 | 10:38 AM
Kwikkordead's Avatar
Kwikkordead
Subscribing.
Was off line for a couple of days.
Sounds like you have it taken care of guys.
Frozen_Joker
17
Apr 10, 2014 08:06 AM
STROKED-OUT
Jun 22, 2013 03:31 PM
SiscoKid
Feb 21, 2013 07:43 PM
dyingtolive
15
Mar 29, 2012 11:56 PM
Bigcat350
Aug 17, 2009 08:46 PM
