Big Red is back on the Road
Well I changed the slave cylinder this afternoon but still no clutch took about 30 minutes. As a few said change the slave and the master cylinder (I know you told me so) so I went back to town and got the master cylinder they both have the life time warranty. Man that little clip holding the sensor on the master cylinder push rod was a pita other than that it was easy to do. After testing it feels good changing gears now. I guess over time you get use to the hard shifting. It shifts easer now with the new clutch and higher lbs pressure plate than it did with the stock set up.
My thoughts are if its just hard to shift its the slave cylinder. But if the pedal goes to the floor its the clutch master cylinder.
Eallend7
02-05-2013 06:31 PM
1994F2507.3L
05-10-2012 04:49 PM
dyingtolive
15
03-29-2012 11:56 PM
f1501987
07-22-2011 09:19 PM
