Copper drownded to death....
Old Oct 1, 2009 | 03:57 PM
  #46
Jermafenser's Avatar
Jermafenser
Originally Posted by 460/5
these trucks had a neutral safety switch on autos, but didnt on manual. unlike new vehicles, you didnt have to push the clutch to start em. personally its something i prefer, seeings as my parking brake doesnt work and my 76 likes to have some throttle working to start. can also get you out of a bind if your ignition gets wet. just a case of bad luck here, with copper.
Yes, that's correct. However, in his signature he says he has a C6.
Old Oct 1, 2009 | 04:03 PM
  #47
kshaneh's Avatar
kshaneh
Yea i did a body swap less than 6 months ago.....
Originally Posted by Jermafenser
Wow. Didn't you replace its body a while ago?
This is why you need to fix things, minor or not, so they work correct. Starting in gear is always a bad thing.
Old Oct 1, 2009 | 06:46 PM
  #48
460/5's Avatar
460/5
Zombie Survivalist
if its an auto, howd it get into reverse in the first place?? shouldnt it have been in park? thats trippy...
Old Oct 1, 2009 | 08:04 PM
  #49
kshaneh's Avatar
kshaneh
That's what im sayin. when i parked it she was in patk. i dont know what happened.
Old Oct 1, 2009 | 08:05 PM
  #50
shanes66charger's Avatar
shanes66charger
Oh, ok so it is an auto.......How the F' did it get into reverse? Why did it not roll away on it own? Trippy **** for sure!
maybe it was just not quite engaged in park quite all the way and popped to reverse when it cranked over.......crazy cray either way?
Old Oct 1, 2009 | 08:14 PM
  #51
shanes66charger
sorry for the loss, but it sounds like the neutral safety switch was likely cooked.not adjusted.etc. Im guessing maybe also your shift linkage was a bit worn? Maybe was partly between gears? Could be why your ignition wasn't working in the first place?
Old Oct 1, 2009 | 08:51 PM
  #52
rsfabrication's Avatar
rsfabrication
Keep the truck and fix it as you can! If that would have happened to a late model truck it would have been a done for!
Old Oct 1, 2009 | 09:00 PM
  #53
Tees77f150's Avatar
Tees77f150
I know you say it is a tough time right now, but if you let it go, you will never see it agian. See if you can keep it, and fix it as you can.
You know how it is when you let one go, then later on wish you would have kept it! Take a little time and think it through.
Even if you strip off enerything possible that is salvageable (sorry, I know that word hurts) to use on another dent in the future at least. That way you would still have some of Copper with you at least.
Bottom line, you need some time to get over this and clear your head, just don't make a decision you wish you had not made down the road, and GOOD LUCK!!
PS: I always thought our dents were about the same color!
Old Oct 1, 2009 | 10:24 PM
  #54
crazyeddie's Avatar
crazyeddie
Man that's terrible n' I'm sorry At least it was in reverse and didn't run you and the mrs. over. Damn though... I hope you and her weren't on a date... that's a hell of a way to end a date
Ever see that old Ford commercial where they drop the f150 from a crane from 10' or so to show the durability of the I-beam suspension? I think it would be bad as hell if you got the motor and trans straightened out and drove it like it is. Not many trucks can go for a swim, get beat up on the winch-out like that, and still drive!
And besides... they do call them the "dent-sides" pickup
Old Oct 1, 2009 | 10:45 PM
  #55
muscletruck7379's Avatar
muscletruck7379
my dads 76 had a problem with not going into reverse all the way and popping out.
i started my capri from under the hood while i was doing some wiring, i agree on how it sucks. i also drove it around in drive for a week after the shift cable snapped (it never had a neutral switch intill installed the c4 over the summer, and of course, half the time it doesn't let the engine start.)
Old Oct 2, 2009 | 06:42 AM
  #56
monsterbaby's Avatar
monsterbaby
I have seen the neutral safety switch mentioned and blamed a half dozen times but I would like to point something out. the OP mentioned starting it FROM UNDER THE HOOD. Sorry jumping the solenoid bypasses ALL safety switches on any vehicle.
Originally Posted by kshaneh
Well today was a day from hell. backed my truck in to a parking spot then left with the fiance. came back and went to start it (had to do it under the hood) and it was in gear... She hopped the curb went down the bank and flipped into the Ohio River. Completely submerged in no time. I will get the pics as soon as i get them..
Old Oct 2, 2009 | 06:49 AM
  #57
i-w's Avatar
i-w
did not know that.
Old Oct 2, 2009 | 08:57 AM
  #58
GLR's Avatar
GLR
If I remember correctly Ford had a recall around 75-76 about certain vehicles jumping out of park.
Old Oct 2, 2009 | 11:37 AM
  #59
shameless's Avatar
shameless
My brother and I know how you feel, we just got his ram 1500 finished completely, from the frame up. a bad snow last winter made him have to drive it (4x4) he flipped it that day, after about a month of having it done. there wasnt a straight panel left on the ole girl. its definately a sickening feeling when your feeling lucky to be alive, but robbed by fate at the same time.
Old Oct 3, 2009 | 02:16 PM
  #60
kshaneh's Avatar
kshaneh
if i had the money to pay them when they got it out i would have ran up to the auto store get some oil, tranny fluid, battery and some gas and see if she would have fired up. if she did it would be out here at her new home. i would strip it down to the frame again, but this time i would sand blast the frame get it powder coated orange or black and go from there. I just got a job yesterday and start on monday. Got alot of bills to take care of b4 i can do ne thing. if nothing i will find a new project. Sometimes its better to start new. aka 460, 4spd, dana 60's....... hmmmm me likie
