6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Particulate Filter
Old Sep 29, 2009 | 04:09 PM
SAE Customs's Avatar
SAE Customs
Particulate Filter
I have a f350 SD diesel. My stupid particulate filter has regened about 14 times a day for the last 3-5 days. What the hell is the problem here. The dealership already replaced the filter once back in march. HELP
Old Sep 29, 2009 | 05:01 PM
sdetweil's Avatar
sdetweil
sounds like they have a problem.. maybe a sensor
Sam
Old Sep 29, 2009 | 05:56 PM
WhiteEx's Avatar
WhiteEx
If you are shutting the truck down before the regen has finished, it will begin again shortly after the next startup. My understanding is that a lot of short trips will also result in more frequent regens. One or two per tankfull is about average.
Old Sep 29, 2009 | 06:03 PM
senix's Avatar
senix
Get it out on the hwy find a good hill, have something to tow and put it to the floor. Make it regen and let it finish, then monitor from there. If you are still having excessive regens it is probably a sensor as suggested above.
Old Sep 29, 2009 | 09:07 PM
silverstang's Avatar
silverstang
It can take a while for a complete regen cycle. Not saying you are, but if you actually ARE killing the truck before a complete regen, then it will lead to issues. If you keep doing so, you will eventually be on the side of the road as the truck will shut itself off until the dealership services it and resets the computer. Also frequent regens can be caused by a few known issues. Could have a faulty sensor as said before, dealer would have to check that out for you really. Also injector issues can cause more frequent regens. Check your oil level and make sure it is not overful. Check the inside of your tailpipe tips and see if they have soot build up on them. There should be almost ZERO soot on the inside of the tips; if there is soot this is an indication of a faulty DPF filter.
BII Plow Truck
Mar 2, 2017 04:01 PM
snickers104
Feb 5, 2017 08:46 AM
djousma
6.7L Power Stroke Diesel
Jul 9, 2014 10:25 PM
ismet7777
Jan 2, 2011 03:01 PM
yeldarb82
Oct 19, 2009 11:08 AM
