fuel pump woes
Old Oct 18, 2009 | 11:52 AM
yeldarb82's Avatar
yeldarb82
fuel pump woes
I am now on my 6th fuel pump in 6mo i put a 3/8 line filter on the suction side and still lost a pump the guys at napa tell me that the filter isnt able to catch all the particulate and that is what is taking the fuel pumps out . What do you guys think?
Old Oct 18, 2009 | 12:22 PM
Action4478's Avatar
Action4478
You may want to drop the tanks & check for junk ... ...
Old Oct 18, 2009 | 02:01 PM
pjwoolw's Avatar
pjwoolw
Have you gone through the bowl and FPR yet?
Old Oct 18, 2009 | 02:20 PM
yeldarb82's Avatar
yeldarb82
yes on the bowl whats there to check with the fpr
Old Oct 18, 2009 | 02:32 PM
pjwoolw's Avatar
pjwoolw
Full it off. Replace 0 rings and clean it. You wont believe all the junk that builds up. It's probably best to pull the bowl and pull it apart too and replace its o rings. I like the o rings available here.
Old Oct 18, 2009 | 02:35 PM
yeldarb82's Avatar
yeldarb82
thanx ill give that a try i am also going to run off my new rear tank solely and see what happens there arnt any shims or anything stupid like that that go under the fuel pump?
Old Oct 18, 2009 | 02:54 PM
pjwoolw's Avatar
pjwoolw
Nope. No shims.
Old Oct 18, 2009 | 03:40 PM
MADVAN's Avatar
MADVAN
Did all the pumps fail on the low pressure side?
How much crud is in your new installed filter?
Performance problems?
Have you run a return line loop test?
It will test for air in the system.
Most times a pump failure is traced to an air leak
into the fuel line or a collapse of the line under a vac.
A high vac on the low side suction of the pump will
kill it no time.
But motor will have running/performance issues way before a pump failure.
I would check the rubber lines at the tank for cracks. Could be you draw air
into the system and it leads you to believe its the pump. The OEM quick
connects are known as a source of the air. A full tank of fuel
will test the lines inside the tank. (no issue full/ issue with tank low)
Have seen tank delam kill pumps. You will see little silver/grey flakes
in the fuel filter.
Bill
Old Oct 19, 2009 | 10:56 AM
yeldarb82's Avatar
yeldarb82
not getting any air but i was getting the gray flecks off the front tank so i guess i should just by a new front tank. the other problem arises also that if i go more than 3/4 pedal about 75% of the time it feels like i am out of fuel (just like a flat spot )
Old Oct 19, 2009 | 11:05 AM
MADVAN's Avatar
MADVAN
Dam Double Post
Old Oct 19, 2009 | 11:08 AM
MADVAN's Avatar
MADVAN
The flakes can/will cause a pump failure.
Its time to replace or boil out the tank.
Back flush the whole fuel system during the repair/replace.
The coating inside the tank is in delam.
Bill
