Sponsored by: Real Truck
change carrier
Old Sep 29, 2009 | 05:45 AM
getnbz's Avatar
getnbz
change carrier
im gonna change gear ratios from 3.73 tp 4.56 do i need to change the carrier too
thnx
Old Sep 30, 2009 | 12:14 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I think that depends on whether or not you are going with aftermarket gears or not.
BUMP! Anyone?
Old Sep 30, 2009 | 12:37 PM
Furian's Avatar
Furian
You Keep What You Kill
If you are using the term "carrier" to mean "differential", then the answer is yes. From what I have seen, 4.10 gears and smaller require one size differential while 4.56 gears and larger require another size differential. I know, what about 4.30 gears? I have yet to find an answer to that question.
Check out Eaton's application guide for confirmation (Page 6 in link below).
http://www.eaton.com/ecm/groups/publ.../ct_128302.pdf
Old Sep 30, 2009 | 12:58 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Yukon gears make the switch somewhere around 4.10, go to broncograveyard.com and pull up 10.5" axle gears, it's have lists of different gear ratios and what carrier they need.
Old Sep 30, 2009 | 02:23 PM
aldridgec's Avatar
aldridgec
Hard to say, there may be a carrier break, but usually there are gears available to get around it.
Old Oct 1, 2009 | 12:07 AM
getnbz's Avatar
getnbz
the gears are aftermarket
Old Oct 1, 2009 | 11:04 AM
EXv10's Avatar
EXv10
Good question but my gut feeling is there is no carrier break.
Old Oct 1, 2009 | 11:41 AM
Furian's Avatar
Furian
Need more proof? Look at ARB's Super Duty application guide (Page 3) below.
http://www.arbusa.com/uploads/PDF/ac...dSuperDuty.pdf
Old Oct 1, 2009 | 12:11 PM
Furian's Avatar
Furian
Something more to consider... Yukon makes "Reverse" gears that for the Dana 60 front axle. These gears can be purchased in a "Thick" version for the smaller differential, which are designed for the 4.10 gears and smaller. For example, you can run a 4.56 "Thick" gear with the smaller differential. However, these "Thick" gears are not available for the Dana 50 front axle. See links below for details.
Dana 50 Front Axle Gear Options:
Ford / Lincoln / Mercury F250 Front Differentials Dana Spicer D50 Rings & Pinions Auto Parts: YG D50R-373R, YG D50R-411R, YG D50R-430R, YG D50R-456R, YG D50R-488R, YG D50R-513R, YG D50R-538R,
Dana 60 Front Axle Gear Options (Note "Thick" versions):
Ford / Lincoln / Mercury F250 Front Differentials Dana Spicer D60 Rings & Pinions Auto Parts: YG D60-354, YG D60-373, YG D60-411, YG D60-430, YG D60-456, YG D60-488, YG D60-513, YG D60-538, YG D60-586, YG D60-617, YG D60-717, YG D60R-354R, YG D60R-37
4.56 Thick Gear for Dana 60 Front Axle:
Auto Parts: YG D60R-456R-T - High performance Yukon Ring & Pinion gear set for Dana Spicer 60 Reverse Rotation in a 4.56 ratio. Yukon exclusively uses 8620 steel in all their Ring & Pinion sets for high strength and long life. They use the latest des
Product Description - "High performance Yukon Ring & Pinion gear set for Dana Spicer 60 Reverse Rotation in a 4.56 ratio. Yukon exclusively uses 8620 steel in all their Ring & Pinion sets for high strength and long life. They use the latest designs and manufacturing technologies to provide a quiet running gear that is strong and easy to set up. All Yukon Ring & Pinion sets come standard with a one-year warranty. Thick gear for 4.10 and down carrier."
However, I did not see any "Thick" gears for the Sterling 10.25 axle.
Sterling 10.25 Rear Axle Gear Options:
Ford / Lincoln / Mercury F250 Rear Differentials Ford 10.25 Rings & Pinions Auto Parts: YG F10.25-355L, YG F10.25-373L, YG F10.25-411L, YG F10.25-430L, YG F10.25-456L, YG F10.25-488L, YG F10.25-513L, YG F10.25-538L,
This leads me to believe that you may be able to keep your OEM differential in the Dana 60 front axle but will have to replace the OEM differential in the rear axle. However, the OP has a Dana 50 front axle so both front and rear differentials will need to be replaced.
Can someone confirm the purpose of the "Reverse" gear design?
Old Oct 1, 2009 | 12:39 PM
EXv10's Avatar
EXv10
Very good Furian, reps to ya!
Old Oct 1, 2009 | 12:42 PM
Furian's Avatar
Furian
Here is some information on the "Reverse" gears. Apparently, the term "Reverse" is synonymous with "High Pinion". I'm not sure if our Super Duties actually have high pinion front axles.
Dana 44 Solid Front Axle: Part 1 Reverse Spiral Housing
Wiklipedia has a great article on the Dana 60 front axle. Note the differential (carrier) gear break point in the article.
Dana 60 - Wikipedia, the free encyclopedia
"Carrier break: 3.54:1 - 4.10:1 and 4.56:1 - 7.17:1"
Old Oct 1, 2009 | 12:48 PM
Furian's Avatar
Furian
Thanks Brent! New Yukon 5.38 gears are next on my wish list so I need to know this information as much as anyone. I'm still not 100% certain so I need to do more research.
matt.likes
Jan 25, 2014 05:32 PM
truckfella
Modular V10 (6.8l)
Dec 31, 2013 09:25 AM
bewford
Dec 28, 2009 07:18 AM
asltrfl
Nov 17, 2007 05:00 PM
