03 vibration/noise
Old Sep 28, 2009 | 09:39 PM
399exp's Avatar
399exp
03 vibration/noise
newb here, 03 explorer w/88k with what appeared to be a wheel bearing noise. When traveling above 20mph noise gradually gets louder with speed and tops out at about 50mph. Noise goes away when slight turning to the right and noisier when turning left. I changed the right front hub/bearing noise still there, changed left front h/b, noise still there. Since steering right made the noise quiet down I suspected front bearings, both have been changed and the noise persists. Is there something that is steering related that I can check or can it be rear bearings? Do they take a bigger beating than the fronts? Tnx-Mike
Old Sep 28, 2009 | 09:58 PM
steve(ill)'s Avatar
steve(ill)
i had a 2002 that had 1 front go out, and 1 rear go out about 20k miles apart, bout in the 70-80k range. Backs are pressed into the knuckle and need a 12-20 ton press to push apart and back together. Other than drive shaft universals, not much else turing that makes noise and increases with speed.
Old Sep 29, 2009 | 07:22 AM
399exp's Avatar
399exp
tnx for the reply, i was leaning towards one of the front half-shafts, maybe the right side, maybe one or both of the u-j's is bad. I've got a 50-50 shot and new front bearings!
jim20j
Escape & Escape Hybrid
Jul 17, 2012 03:58 AM
trevstaff
Feb 25, 2012 07:25 PM
mpriester
1997 - 2003 F150
Dec 22, 2010 04:17 PM
pete315
May 24, 2010 10:30 PM
rasta
Aug 7, 2009 09:25 AM
