Shuttering
Old Sep 28, 2009 | 07:36 PM
svtwin73's Avatar
svtwin73
Shuttering
So I've searched this forum for about 2 days and can't find anything about 2 problems I have.
I have a 98 Ranger 4x4
First, my A/C makes a shuttering noise when I turn it on. It makes this noise now and then when on, but when turned off, nothing. Is this a symptom of a failing compressor? It still blows cold air and I've replaced the blend door.
Second, the front wheels make a "rotating" squeek at speeds greater than 10 mph. Go figure, you can't put it on a lift and find it. It seems to squeek at a slower rate than the speed of the wheel/tire. This one has me confused.
Old Sep 28, 2009 | 08:07 PM
brad1975's Avatar
brad1975
as far as your a/c sounds like the bearings are going out in the compreser
Old Sep 29, 2009 | 12:31 AM
g_k50's Avatar
g_k50
AC is the clutch, only runs when it's turned on.
Squeak, check the brake components, then hubs. Look for shiny metal where it's rubbing and squeaking.
Old Sep 29, 2009 | 04:42 AM
svtwin73's Avatar
svtwin73
Are the bearings replaceable or just replace the compressor?
I thought about the air gap and had the adjust that already, it was at 0.038
Old Sep 29, 2009 | 06:20 AM
pawpaw's Avatar
pawpaw
Not clear on whats "shuttering", but if you mean the engine idle gets rough when the A/C is turned on, maybe add the IAC to your suspect list.
If it's the compresor itself thats acting out, maybe suspect it's clutch is slipping, or maybe highside pressure, or maybe the serp belt, or tensioner.
More thoughts for pondering.
Old Sep 29, 2009 | 04:55 PM
svtwin73's Avatar
svtwin73
It sounds like a loose pulley, I replaced the serp belt. There was an old one on there, previous owner. I'm having a mechanic look at it tomorrow.
Old Sep 29, 2009 | 06:02 PM
pawpaw's Avatar
pawpaw
When you had the old belt off, did you check all of the accessory pully bearings, like the water pump, idler, tensioner, ect, for play/looseness, or roughness????
Have you raised the hood & had someone turn the A/C on, while you looked/listened for the shutter????
Old Sep 29, 2009 | 06:14 PM
svtwin73's Avatar
svtwin73
I didnt check the acc. pulleys, I might before I take it in.
Its not a constant noise, its on and off so I need to check if its doing it when the a/c kicks on/off
jtexfisher
May 14, 2014 04:06 PM
dblakney
May 18, 2004 08:28 PM
iNFoRMaLiTY
1997 - 2003 F150
23
Feb 27, 2004 11:49 AM
rhetor
Jun 11, 2003 05:26 PM
