352 ? harmonic balancer
Old Nov 26, 2009 | 05:39 PM
410 Highboy's Avatar
410 Highboy
I am helping a friend sort out a 69 F-100 with what he was told has a 352 . Right now it is mannual steering ,no A/C. It has a 3 belt pulley attached to the front of the harmonic balancer . The 3 belt pulley has been balanced . I can see the drill bit holes . The front pulley rotates smoothly . The damper which carries the belt for the waterpump and the alternator wobbles. I told my friend to get rid of the 3 belt pulley and buy a new harmonic balancer . I found a Professional Products damper. I have had good luck with their product on a 351. Just looking for some insight .I don't know why someone would put that 3 belt pulley out their with no belts to run . The more simple the better . A single belt pulley on the crank and water pump is what I recomended.
Old Nov 27, 2009 | 07:31 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
The Pro Products balancer is a good choice. I bought the SFI version and it's very nice. The PP balancer should come with a single groove pulley and a new timing pointer. He should be able to get them from NAPA or any good vendor. Last time I looked NAPA also sold a OEM style FE balancer. Seems to be a decent part as well. Not sure who makes it though.
Old Feb 12, 2010 | 12:46 PM
Gr8Cook's Avatar
Gr8Cook
Is the damper supposed to be a press fit? I pulled mine off (75 390) and it slide off like a Japanese crank pulley.
Cook
Old Feb 12, 2010 | 02:01 PM
MeanGene427's Avatar
MeanGene427
Here's a nice American- made in Newark, CA, very good quality, SFI 18.1 certified unit- 7 different versions available. I just put this particular one on a 450ci stroker 428CJ, it fit perfectly, checked the timing marks and it was within 1 degree- not bad
7 FE Ford Internal Balance Harmonic Damper : BHJ Dynamics, Harmonic Dampers and Specialty Crankshaft Vibration Dampers
Artf0rm
Feb 11, 2017 09:38 AM
jsfrenchfl
May 26, 2016 12:01 PM
Spyderjohn
39
Jul 11, 2012 01:18 AM
SuperSabre
Jan 15, 2011 07:47 PM
OldBlue'72
Aug 17, 2006 12:36 PM
