Offroad & 4x4
Front Shackle Reversal
Old Sep 26, 2009 | 01:03 PM
BAD351W's Avatar
BAD351W
The 3 inch shackle reversal kit should give my F-250 a level stance like an F350 right?
Old Sep 26, 2009 | 05:24 PM
79f150toy's Avatar
79f150toy
Will the shackle reversal work for the TTB? I thought it was only for 350s. it may alter the susp geometry and make alignments a pain..i dont think it come with axle pivot brackets that you may need..now it would prolly be better if you had a D60 under your truck(which it might have). If you did the SAS on it and used the 350 springs then it would be the same height up front as a 350...I retained my 250 ttb springs when I did the SAS and it lifted the front about 2"-so now the front and rear are pretty much level(which I dont like)
Old Sep 29, 2009 | 10:40 PM
captain p4's Avatar
captain p4
I believe you can use it with a TTB front on the two fiddy if you get drop brackets.
Old Oct 2, 2009 | 02:08 PM
86sixbanger's Avatar
86sixbanger
I thought you needed different springs for the d60 anyway when you did the swap....
rickdavis81
Apr 10, 2014 06:59 PM
matowns21
20
Dec 16, 2011 06:29 AM
Scramblermaster
Offroad & 4x4
Oct 12, 2010 12:34 PM
Coalroller
20
Feb 10, 2010 06:35 AM
