Rice toooo Reallllll
Ok previous truck 08 tundra with big engine and trans. Mods where filter, tuner, exhaust. It was a nice truck but it was not a real truck. I drove the you know what out of it but it was just not the all around work truck i wanted. I now have now bought a 03 6.0 250 ext. cab. I use my truck for work. Sometimes i haul a big inclosed trailer sometimes im hualing tons of whatever on and open trailer. Sometimes just need to hualass accross town. I need to be able to idile my truck at times to. Should i leave my truck bone stock or what proven long term mods should i make?
Prolonged idling isn't good for these trucks. If that's something you need to be able to do, check out this link on how to perform the 'high idle mod' http://dan.prxy.org/Truck/Other/High..._idle_mod.html.
on
A good 4" exhaust would be sufficient for most people out there. Bigger isn't better with exhaust as you will lose low end grunt if you bump it up to a 5" without the support of more air and fuel from bigger injectors and turbo.
Tuner I would either get SCT's X3(do not get the LiveWire, 50/50 chance you'll get a bad one) or the Spartan Phalanx. The Spartan Phalanx has more features, but the price might get you down. Both are very good and both offer custom tunes which have been shown time and time again to be the best thing for the 6.0 if you are going to tune it for the longevity of a tuned engine.
Idling with these trucks can be a bad thing as well unless you install a high idle circuit on there. If you have the upfitter switches then it should be easy enough to do, info I believe is still in the tech folder in this forum. If you idle it quite a bit without a high idle circuit your asking for EGR, turbo issues. Might take awhile, but it will happen.
I would also use synthetic motor oil(I use Mobil 1) for your changes. That has been known to do good things for the injectors and turbo.
Here's a link: https://www.ford-trucks.com/forums/forum145/
on
It IS simple. You spent longer reading about it than it would take to actually do the mod. You just need some 1" hose, I used some PVC glue, a plug for the intake tube, and some hose clamps. I forget what size plug I used but you can get everything you need to do it at a Lowes or Home Depot for less than $10, depending on how long the hose needs to be and that depends on where you would like it to exit. Mine vents to the atmosphere before the rear axle, @ 10 feet maybe? But I already had the PVC glue. Another "almost must-do" mod is the coolant filter, unless one has already been installed.
breedo99
66
06-23-2015 12:13 PM
jlsuhr
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
16
03-07-2008 09:54 PM
Buggie
03-12-2003 02:01 PM
