ICP above/below desired?
Old Sep 26, 2009 | 01:47 AM
brad7.3's Avatar
brad7.3
On occassion when I start my truck, the check engine light comes on. So when I check it with my Edge programmer, it reads: P1211 Injection Control Pressure above/ desired. What does this mean? how to fix it?
Old Sep 26, 2009 | 05:52 AM
c00nhunterjoe's Avatar
c00nhunterjoe
my guess is the truck is having a hard time building high pressure oil at start up. my suggestion is check your icp connection first and if that is clean and tight then check your ipr o-rings
Old Sep 26, 2009 | 10:57 PM
brad7.3's Avatar
brad7.3
Hey Coonhunterjoe, I think you mave have solved the problem. I took a look at the connections, and on the pigtail to the IPC the three individual wires with plugs all had damaged insulation! So I just got done soldering in some good wire. and in a little bit, Im gonna give it a try.
Old Sep 27, 2009 | 11:47 AM
brad7.3's Avatar
brad7.3
So I "rehabbed" the wire harness, and it is still doing the same thing.
Old Sep 27, 2009 | 08:14 PM
IDMooseMan's Avatar
IDMooseMan
If the ICP connections are good, check the oil level. If the oil level is too low (or the oil is old) the HPOP can't build up enough pressure to fire the injectors reliably. It just gets worse when it's colder outside.
Did you clear the codes after the ICP was 'rehabbed'?
Old Sep 28, 2009 | 08:22 AM
Brown Falcon's Avatar
Brown Falcon
check the oil level in the HPOP itself. Should be about a 1/4" from the top...
Old Sep 28, 2009 | 09:05 AM
Talyn's Avatar
Talyn
Mine was at the top when i checked my HPOP..
So it should be somewhere up there close.
The ICP connector is fragile too I noticed.
Typical crappy automotive design. It looks like you could pull the wires right outa the connector when I was dorking with it.
Yea, make sure you clear codes. You might have just re-read the hung code.
Bigblockboy
17
Oct 11, 2016 07:55 PM
COMTNMAN
Aug 23, 2016 10:35 AM
trevorrules
May 9, 2016 05:46 PM
aquaman
6.4L Power Stroke Diesel
Nov 8, 2012 02:24 PM
Rod Robertson
Apr 1, 2005 05:52 AM
