Arizona Chapter Join Chapter, Leader:
garage door insulation
Old Sep 25, 2009 | 04:59 PM
PilotRob's Avatar
PilotRob
Has anyone tried it?
I've looked online at what Lowe's has to offer. The Owens Corning kit has a higher R value but the user reviews are not promising. The Insulfoam kit seems to be the way to go, but not as high of an R value. Our garage faces SW, so it heats up like an over during the day thanks to the fact that it's metal. My pregnant wife doesn't like roasting when she comes home from school.
Thoughts?
Thanks!
Old Sep 26, 2009 | 09:40 AM
helifixer's Avatar
helifixer
i have always bought insulated doors but it doesn't look to hard to buy the foam from Home Depot or Lowes and insulate them, what I looked at was pre cut for width you just had to cut the length. also check the attic above the garage for insulation if it isn't have it blown in, that made a huge difference on my house in Glendale and my house in Bullhead
Old Sep 26, 2009 | 09:47 AM
Dually TAS's Avatar
Dually TAS
The kits from HD install in about 15 minutes and make a huge difference. Likewise I insulated my attic to 18" this last spring and saved over $100 a month this summer on my electric bill.
Old Sep 26, 2009 | 11:44 AM
kstones63's Avatar
kstones63
I have insulated garage doors and insulation in the attic over the garages. It seems to make a big difference to me. The insulation companies don't suggest to put insulation over the garage but I think that it is a good idea.
Before anybody goes to Home Depot, buys insulation for the attic and rents the machine to spray it in, you should check with an insulation company to have them spray it in. It isn't very expensive to do. Have it sprayed in over your garage and add to the rest of the house.
The H.D. garage door insulation kits are just like what comes on an insulated door and very easy to install.
Kevin
Old Sep 26, 2009 | 07:33 PM
helifixer's Avatar
helifixer
Kevin
I will second the insulation company (I use Banker Insulation as the founder was a good friend of the family and we rented a farm from him for years) anyhow when you fall through the ceiling it sucks to be you! when they fall through the ceiling their insurance pays for the repair.
Old Sep 27, 2009 | 08:44 AM
MikeB 88's Avatar
MikeB 88
I bought several sheets of that pink foam insulation. Cut, fit and glued it to our doors. It made a big difference. It's been up there for around 5 or 6 years now with no problems.
Old Sep 28, 2009 | 10:44 PM
muleguitar's Avatar
muleguitar
how about installing a couple of vents? one down low on an exterior wall, and one up high. maybe even go a step further and put a motor on one of them.
Old Sep 29, 2009 | 07:02 AM
SGnAZ's Avatar
SGnAZ
Ceiling fans can be a big help as well
Old Sep 30, 2009 | 11:27 AM
PilotRob's Avatar
PilotRob
Great thoughts and suggestions. Thank you!
We're in a two-story, and the guest room and baby-to-be's room are above the garage. I'll have to head upstairs and see how much (or little) insulation is above up top. I'm thinking this is a definite "to do" when I get back. So quick and it'll pay for itself in no time at all.
Lately I've started leaving the garage door open about 3" - 6" when I'm home to help keep the temps down. Amazing what a difference that makes, too.
Old Sep 30, 2009 | 01:48 PM
helifixer's Avatar
helifixer
having the attic above my garage in Bullhead blown 9 inches lowered the temp about 20 degrees inside the garage.
joe doyle
Jul 29, 2012 09:23 PM
corn-dog
Apr 7, 2012 07:44 PM
dmanlyr
Aug 12, 2010 11:19 PM
PilotRob
Arizona Chapter
Jun 7, 2010 07:23 AM
Jerry R. Owen
New Member Introductions
Jan 1, 2005 06:01 PM
