duraspark vs. ???
Old Sep 25, 2009 | 10:32 AM
crescentwrencher's Avatar
crescentwrencher
duraspark vs. ???
ive got the durasparl dist. how much increase in efficiency would i get by going to an msd?
Old Sep 25, 2009 | 11:55 AM
jowilker's Avatar
jowilker
I'd say none for a daily driver, electronic ign. is electronic ign.
A high dollar racing operation could be different.
John
Old Sep 25, 2009 | 12:16 PM
Bear 45/70's Avatar
Bear 45/70
I would agree with jowilker. If it was a points system, that would be different. I would go farhter than jowilker and say, unless you have an all out race motor, the msd is a waste of money.
Old Sep 25, 2009 | 01:42 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
MSD may be fine, I've never owned one personally, but the Duraspark is cheap, available, and very tunable once you understand the recurving process. I've just read too many posts with MSD problems to buy one. Duraspark may fail but a whole lot cheaper to fix. But just my opinion.
Old Sep 25, 2009 | 01:53 PM
Bear 45/70's Avatar
Bear 45/70
True about the cost. You can carry a spare Dura-spark box and sensor (trigger/stator/pickup if you prefer) for way less than the msd is gonna cost you.
Old Sep 25, 2009 | 02:55 PM
crescentwrencher
where can i get information for tuning the duraspark?
Old Sep 25, 2009 | 03:38 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Here is one link:http://www.fordmuscle.com/archives/2...ng/index.shtml
And another: http://www.carbdford.com/viewtopic.php?t=5543
Here is a place that will sell you one custom tuned for your engine: http://www.performancedistributors.c...dduraspark.htm
There is a vendor on this site also. Just can't remember who.
Old Sep 26, 2009 | 09:03 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I will say one thing for the MSD - it cures cold-start problems, and band-aids lots of other tuning or cam screw-ups.
The multi-spark is a good thing when you're running the hairy-edge even with "only" a 290/290 cam.
Then, if you get the rev-limiter version (6AL), you can keep your motor together when you drop that transfer case driveshaft while mudding with your foot to the floor
Old Sep 30, 2009 | 10:37 PM
fordeverpower's Avatar
fordeverpower
I also think the duraspark is fine i turn 6000rpm, no problem with one. My buddy doesn't like them dirt tracking the durapsark box, so he uses the msd 6t box with a ford dizzy. We thought maybe the vibration or valve spring pressure may have been the culprit.
I personally want to try a crane cams hi-6n box, it has an adjustable dial rpm limiter. I have heard complaints of msd limiter plugs being off.
Faron Rhodes over on ford fe recurves them and does Scott Johnston at reincarnation automotive
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
