Scanner datastream results...normal?
Old Sep 24, 2009 | 10:07 AM
BigJake34452's Avatar
BigJake34452
hey i did a datastream of a few things on my truck just wondering if all of it was normal. BTW, this was all at IDLE.
ICP pressure fluctuating rapidly between 472-501
ICP voltage fluctuating rapidly between 71-87
Fuel pulse width 2.5-2.6
i had 2 selections for engine oil temp so i chose both,
first one was reading 224 F
second was 141 F
IPR steady at 11%
coolant temp -40....wtf?
this was at operating temp.
Old Sep 24, 2009 | 12:47 PM
Pocket's Avatar
Pocket
Your oil temps are a little weird.
You have a 6-speed, so you should have a coolant temp sensor reading through the PCM. -40 is a weird one.
Your ICP pressure and voltage are normal, as is the IPR duty cycle.
Old Sep 24, 2009 | 08:34 PM
BigJake34452
anyone seen oil and water temps like this
Old Sep 24, 2009 | 09:11 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I'm just wondering if your scan tool might interpret your ECT reading as the an EOT reading. As Curtis pointed out, the 6-speed trucks actually use an ECT input but I am going to assume that your ECT is actually depicted as a second EOT reading since a -40 ECT sensor input would set an open circuit code.
Old Sep 24, 2009 | 09:32 PM
BigJake34452
i do have a soft code every time that is IAT circuit high input, would that have anything to do with it?
wackercattle
Feb 23, 2015 10:00 PM
ollirrap
22
Dec 22, 2014 10:11 AM
SturgeonHunter
Oct 13, 2010 12:08 AM
Justin03PSD
19
Sep 9, 2009 05:34 PM
grousehunter
Oct 16, 2004 02:05 AM
