Scanner datastream results...normal?
hey i did a datastream of a few things on my truck just wondering if all of it was normal. BTW, this was all at IDLE.
ICP pressure fluctuating rapidly between 472-501 ICP voltage fluctuating rapidly between 71-87 Fuel pulse width 2.5-2.6 i had 2 selections for engine oil temp so i chose both, first one was reading 224 F second was 141 F IPR steady at 11% coolant temp -40....wtf? this was at operating temp. |
Your oil temps are a little weird.
You have a 6-speed, so you should have a coolant temp sensor reading through the PCM. -40 is a weird one. Your ICP pressure and voltage are normal, as is the IPR duty cycle. |
anyone seen oil and water temps like this
I'm just wondering if your scan tool might interpret your ECT reading as the an EOT reading. As Curtis pointed out, the 6-speed trucks actually use an ECT input but I am going to assume that your ECT is actually depicted as a second EOT reading since a -40 ECT sensor input would set an open circuit code.
i do have a soft code every time that is IAT circuit high input, would that have anything to do with it?
