Offroad & 4x4
Shift linkage (to short)
Old Sep 23, 2009 | 09:27 AM
85mudtruck's Avatar
85mudtruck
okay so i put my body lift on 3" and now my shif linkage is to short. its only short by 1/4 inch at most not even.
its a 85 ford f-150 302
i havent realy looked is it adjustable or am i gonna have to cut and extend.
any ideas will be great thanks.
Old Sep 23, 2009 | 10:47 AM
75F350's Avatar
75F350
This is an automatic transmission right? If you have not adjusted it yet, it is shorter than 1/4 of an inch. It will be short by three inches.
Anyway, you can shorten it or make a new linkage. That bushing that retains the linkage into the shift lever on the column can be a pain to remove.
In many cases, I cant ever seem to get the linkage back in, so I replace the bushing with a shperical rod end and home made linkage. This provides plenty of adjustment and maintains a very smooth operation.
Old Sep 23, 2009 | 12:35 PM
79f150toy's Avatar
79f150toy
autozone/advance sells the bushing kits if yours gets destroyed....they usually have them in stock. I dont recall the p/n but they should have a book so you can look it up. BTW, on my truck(90 250), the linkage is adjustable-there are two bolts you loosen to adjust it...
Old Sep 23, 2009 | 12:48 PM
85mudtruck's Avatar
85mudtruck
okay so i adjust it at the column? sorry but this is first time i have done anything other then a motor.
thornton1979
Jan 5, 2014 07:47 AM
abyars111
13
Aug 22, 2013 10:33 AM
Tobys351.9
Apr 8, 2013 02:12 PM
Pathogen98
Aug 14, 2011 03:04 PM
LARIAT 85
Sep 24, 2007 08:35 PM
