Electric Trailer Brakes
Old Sep 22, 2009 | 10:51 PM
fire3110's Avatar
fire3110
I have an 08 Expo EL EB. My Dad has an 08 Expo EL Limited. His came with a trailer wiring hookup with both the Class I (4 Pin) and the Class IV (7 Pin). Mine came only with the 4 pin. We have a large 24' trailer with elec trailer brakes. His has the brake control mounted in it and the trailer brakes work great when plugged into the 7 pin. We intalled the brake control as Ford put a plug for it under the dash. I have the same plug under the dash. If I get a brake controller will the trailer brakes work with my 4 pin connector at the rear of the truck? If not what do I need to do? I didnt find much help in the manual. Thanks in advance.
Old Sep 23, 2009 | 11:42 AM
J_E_Summit's Avatar
J_E_Summit
4 Pin is for lights only.
You would have to install either a 6 pin or 7 pin connector. I don't know about down there, but 6 pins connectors are becoming really uncommon around here.
Old Sep 23, 2009 | 12:12 PM
mel2000f150's Avatar
mel2000f150
Your local RV parts store will have a 7 pin connector cable that will plug into your wiring harness.
Old Sep 23, 2009 | 08:30 PM
fire3110's Avatar
fire3110
Ok. Thank you. I saw under the rear bumber a wire labeled elec brake control but it does not go to anything. Thanks for the input.
Tifford
Electrical Systems/Wiring
Sep 14, 2013 05:54 PM
gogreenwave
1983 - 2012 Ranger & B-Series
Apr 16, 2012 09:38 AM
fire3110
Nov 11, 2009 12:34 AM
johnEboy
Apr 20, 2008 12:34 PM
72soa
Oct 23, 2007 04:23 PM
