No spark
Old Aug 10, 2012 | 01:53 PM
rangergirl94's Avatar
rangergirl94
No spark
I have s 93 f150 4.9 I started it today and it just died it has no spark changef coil no change
Old Aug 10, 2012 | 02:23 PM
f-150_1993's Avatar
f-150_1993
How did you check for spark?
Old Aug 10, 2012 | 02:40 PM
rangergirl94
Spark tester that lights up
Old Aug 10, 2012 | 02:46 PM
f-150_1993's Avatar
f-150_1993
Never used one, hmm and it was placed on the coil wire to test? Is the coil brand new?
Old Aug 10, 2012 | 03:07 PM
bashby's Avatar
bashby
Ignition module is most common failure. Remove it and take it to your favorite auto parts store, most of them can test it. You can remove the dist cap first, make sure the rotor turns with the engine.
Old Aug 10, 2012 | 03:09 PM
f-150_1993's Avatar
f-150_1993
Yea the ignition module either works or it doesn't might be that if there is absolutely zero spark. Its a common problem
Old Aug 10, 2012 | 03:34 PM
rangergirl94
Does it icm have to be monted to the fender to ground I tried another off a running truck no chage but I didnt bolt it up
Old Aug 10, 2012 | 03:36 PM
f-150_1993's Avatar
f-150_1993
Well I'm pretty sure it has to be attached to the frame thingy the icm is mounted on and then attached to the fender
Old Aug 10, 2012 | 03:40 PM
rangergirl94
It started smoking in the cab when it died I pulled computer it smells burnt so I pulled it outta parts truck still nothing
Old Aug 10, 2012 | 04:48 PM
rangergirl94
I fixed it giys thanks for all ur help it was the red wire on the plug for the coil it was coroded but connected I accendently broke it off so I rewired another plug on it
bruce67
Feb 25, 2017 08:12 AM
octobull
Electrical Systems/Wiring
Oct 20, 2008 11:50 AM
irishpilot
Apr 28, 2007 10:55 AM
cbjr61
Aug 4, 2005 10:30 PM
