rust??
Old Sep 22, 2009 | 04:17 PM
69ford99's Avatar
69ford99
rust??
I washed my truck and noticed some specs of rust all over the front fender and on the hood. I tried to rub it out with rubbing compound but it didnt do much. Whats the best way to get rid of it? What grit sand paper?
Old Sep 22, 2009 | 05:57 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
I was under the impression our hoods where aluminum should not rust.
Old Sep 22, 2009 | 06:11 PM
442w30's Avatar
442w30
Had a white truck that came with the orange dots on hood and roof years ago... acid rain. Ford hoods are aluminum so you do not have rust there. Dont use sand paper!!!! Have a detail shop look at it, I suspect it is overspray or a type of acid rain damage.
Old Sep 22, 2009 | 06:42 PM
rplatt56's Avatar
rplatt56
it also could be rail dust. These can only be removed with a clay bar. This is caused by the metal bits coming off the rails during transport on a train.
Old Sep 22, 2009 | 10:15 PM
stronger's Avatar
stronger
or it's just the crap that they mix with road "salt" these days, or its brake pad residue that shot up there hot off the pads and stuck. go buy a better rubing compound or "pre-wax cleaner". Don't sand it!
Old Sep 23, 2009 | 12:26 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
go buy some Clay Bar
then spend a bit of time using that on the hood. any particulate your hood collects from road debris can cause this to happen.
if you are lucky, it's just some tar or other crap. as said earlier, the hood is aluminum...so lets hope it isnt' some sort of corrosion
Old Sep 23, 2009 | 12:48 PM
Ryan50hrl's Avatar
Ryan50hrl
its easy to fix....go buy a clay bar (an not the cheap ones at walmart or autozone) go to a body shop supply store and buy a good clay bar, it should cost you about 30 bucks.....claybar the whole truck, wax with a high quality wax, and your truck will look better than new.....i do mine once or twice a year.....
Old Sep 23, 2009 | 06:31 PM
magnet1's Avatar
magnet1
Get a clay bar kit from Mcguires. Comes with everything you need. There are also many videos on You Tube on how to clay a vehicle. That should remove any contaminates. I do mine every year just to get the baked on dirt out of the clear coat.
RedDirtLandscaping
Sep 22, 2009 08:22 AM
MacAries
Oct 20, 2004 08:57 AM
Jesse2
16
Sep 30, 2003 06:43 AM
fordtrck302
Offroad & 4x4
Jan 11, 2002 05:55 AM
