Leaf Spring Center Pins
Old Sep 22, 2009 | 12:34 PM
BigD_ca's Avatar
BigD_ca
Can anyone tell me what the center pin diameter and length are for the 4 stock leaf spring center pins on a 2004 F150 4x4 Screw?
I have an extra leaf I would like to add but no center pins and my local suspension center wants to know the size. It looks to be either 7/16" or 1/2" diameter and about 2 to 2-1/2" long but I need my truck so I can't start pulling it apart right now. Basically I will just add another 1/2" to the stock length to accomadate the addition of a new leaf.
Thanks.
Old Sep 22, 2009 | 07:54 PM
msgross's Avatar
msgross
don't worry about the length, you can cut it off when done... I'd buy a set of each and see if you can take the other back...
Old Sep 22, 2009 | 08:17 PM
Ford Fx4's Avatar
Ford Fx4
True, but off the top of my head I can't remember if you can even get to the bottom of the leaf pack with out, taking it out??
If you can get to it, and decide to cut the extra length off make sure you thread the nut first.
Old Sep 22, 2009 | 10:10 PM
stronger's Avatar
stronger
Call your ford dealer and ask the parts guy/woman. there parts blow-up will list the specs. We have a parts lady here, she's the best. I've been calling her for odd stuff like that for 15 years.
you already know but for the next guy, the dual center bolts on these newer trucks are a bit larger than they use to be. the heads are too. off the shelf ones from napa or the like would likely not fit.
post up the specs when you get them.
Old Jan 24, 2011 | 05:41 PM
gixer311's Avatar
gixer311
I can't believe I have to revive this thread...but I need help on these bolts! I am trying to add roadmaster active suspension spring, but I can't get the nuts off the centering pins for the leafs. I was going to start cutting, but I though that I should get new nuts and bolts first. Long story short...Ford parts guy told me that center pins are not sold separate from the leaf, I would have to buy the whole leaf! Went to a truck shop (deals with big rigs) and said that he has hundreds of the bolts and that he would install them, but he wanted to do it for $150 PER SIDE!!! What the heck is so special about these bolts??? Where can I get them? Tasca parts does not show them on their exploded view of the rear suspension either.
Old Jan 27, 2011 | 10:19 AM
msgross's Avatar
msgross
do you have a local spring shop or mchine shop? Mine can get me anything...
Old Jan 27, 2011 | 07:22 PM
gixer311's Avatar
gixer311
Well I did get a local parts store to order some...although, they were not sure what size so they order what was most common. With that being said, I went and got a new impact gun and some nice vice grips and got them off with no problem. So i didn't need them anyways. I think they ordered 3/8" x 4-1/2", but there was also 5/16", and 7/16" (with many different lengths).
Outlaw56
Feb 4, 2017 09:40 AM
Ed250
Apr 16, 2016 12:06 AM
Joel Cassell
Apr 3, 2016 08:12 PM
Rogers F100
Sep 28, 2015 04:23 PM
FordOwnerJoey
Jun 21, 2012 06:18 AM
