I know a lot of people are going to rear disks recently and I will be soon.
I'm wondering if there is a stock type proportioning valve off of a stupid duty or something similar that people have used with luck when converting?
I am switching to a hydroboost at the same time and will be keeping the stupid duty master cyl. as that is meant for rear disks.
I was planning on running the in cab, adjustable proportioning valve, but I'd like to know if someone else has had luck with one off of a different year/model?
I don't. I'd be the one to go to an autoparts store and have them look up "proportioning valve" for a 2002 F-250. No I don't know eactly what it is but that is what my hydroboost and master cyl. came out of so I'd be tempted to try it and see how it worked.
Sure - why not. It's been forever since I've made it to a yard - so if you see one on a rear disk truck - grab it and I'll pay ya for it plus shipping!
I take offense to that, Steve. I used an adjustable on mine but my buddy left the stock one in place on his Blazer when we did it and it works just fine. Trial and error seems to be the way most go about it but I like the SUPERDUTY idea.
Nothing "super" about um hahahahaha
Stupid duty might have metric fittings - never though about that. Gotta love the retards at Ford going over to metric.... Oh well - it is what it is and I will have to figure it out. Everything else on my truck is custom - so why not the entire brake system as well
That whole magic combo with this entire thing is just that, magic. Identical trucks with the same components have had different results.
In fact the last time I was messing with this, I tried several combos, and ended up using an adjustable one. Much easier this way.
Some late cheby trucks had a Disc/disc set up and the biggest issue was the master cylinder. Some times the small reservior can run out of fluid and then the brakes are introduced to air, and they fail. Disc/disc masters have a common sized reservior front to rear, or simply one huge reservior. This seems to be the hot ticket when the piston is capable of producung the correct amount of fluid and pressure.
There is another option, some E-350 vans had rear disc brakes. Short school buses (you know some of you know exactly what I am talking about) and cab and chassis vans with a single rear wheel had rear disc brakes. These master cylinders and prop valves are pretty good to use, but they can be spendy and difficult to find used.
I have left stock prop valves in and been successful, so this is still magic. Sometimes something works and other times the exact same recipe does not work so well.
The one thing that works every time, is the adjustable valve.
Nice to be able to compensate for different loads, and even terrain.
Adjustable is easy and effective.
What about this one ? Ebay#290347808464. Nobody ever answered if the late model prop valves might have the metric fittings.
