altenator issue
Old Sep 26, 2009 | 10:45 AM
bismic's Avatar
bismic
I personally think that my voltages are on the low side of acceptable.
If you see voltages much lower than mine, then I would say it warrants further investigation.
Checking the voltages at each condition I listed can be helpful in deciding whether or not you have a problem IMO.
Also, load testing is the first step when you even think you have a problem. I think you should load test every 6 mos to a year - regardless of problems.
Old Sep 26, 2009 | 11:18 AM
69cj's Avatar
69cj
I also believe in float charging over night every couple of months to reduce sulfation and to keep the batteries at their peak. Hopefully will give you the max life out of your batteries but that could be debated.
Old Sep 27, 2009 | 06:44 AM
juneau76's Avatar
juneau76
Thanks for the input guys. I guess I need to look into getting a voltage meter. Been thinking about getting one for a while now; this should be justifiable with the CFO.
Old Sep 27, 2009 | 10:53 AM
desertt5's Avatar
desertt5
I am using a ScanGauge II for my voltage, water temp, and tranny temp. Works great and frees up room for the other important gauges. Cheaper too.
Jason Lilly
Modular V10 (6.8l)
Jan 28, 2016 02:17 PM
Pitcrw6
Aug 26, 2012 12:59 PM
Slankky
Aug 19, 2012 02:02 PM
Benmierau
Feb 16, 2012 07:59 AM
04-F250SD
Oct 10, 2010 02:15 PM
