temp guage not working
Old Sep 21, 2009 | 08:24 PM
utahnate's Avatar
utahnate
Hey this is kind of a dumb question, but i wanted to get some opinions. I changed that thermostate and flushed out the radiator with no results. I was driving my 76 highboy that has a 390 with 20 grand on it since the rebuild. The temp guage in the dash stopped working and went to cold. I changed the thermostate and flushed the radiator the guage started to work for a minute then just feel back to cold again. When i flushed out the radiator the old fluid was brown from rust im guessing? could this be the problem? I appreciate any help i can get. Thanks
Old Sep 21, 2009 | 10:43 PM
shanes66charger's Avatar
shanes66charger
A) put in a manual temp gauge
2) I wouldn't think the fluid should have looked that bad with only 20k on a rebuild??
Old Sep 21, 2009 | 10:56 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Sounds like the wire to the temp sending unit might be loose. Its located at the front of the intake manifold behind the distributor. If its not loose, ground the wire and see if the needle moves all the way to "H". If it does then probably the sending unit is bad.
Old Sep 22, 2009 | 11:01 AM
trapperjack's Avatar
trapperjack
Just replaced the sending unit in mine, fixed the temp gauge for $4 and change.
Old Sep 22, 2009 | 12:00 PM
montana_highboy's Avatar
montana_highboy
That's the only way to get an accurate reading, the factory gauges don't really tell you much (even when they're working).
Old Sep 22, 2009 | 12:32 PM
shanes66charger
yes, I am not against factory gauges, I just prefer to in addition, have a manual as well.
Old Sep 22, 2009 | 02:55 PM
old76er's Avatar
old76er
I was working on my 360 and had that problem with the water getting dirty even after i changed the radiator, turns out that I had a leaking freeze plug so I went to change that and found there is a ledge in the water port (behind the freeze plug, inside motor) below the hole for the freeze plug it was catching anything and everything going through the motor. There was sand and rust (farm truck) in the motor, I cleaned out about 9 cups of stuff with my fingers and then flushed it with water, it never happened again
Old Sep 23, 2009 | 08:13 PM
utahnate's Avatar
utahnate
Thanks for the advise. I'll go and see what i can figure out. How hard is it to put in a manual temp guage?
Old Sep 23, 2009 | 09:14 PM
montana_highboy
If you can change your own thermostat (as you did) you can install a manual temp. gauge, it's very easy, you can either a) install it where your factory sending unit was on the intake or b) install it in your thermostat housing and maintain the use of both gauges.
Old Sep 23, 2009 | 09:33 PM
utahnate's Avatar
utahnate
Sending unit was the problem. I never thought that would be the problem with the engine having so few miles on it. I guess it had been eight or nine years since the rebuild. I bought the truck from an old man who only used the truck a few times a year to pull his camper up to the lake. The truck only has 81,000 original miles on it.
I do want to put a manual temp guage on the tuck. A manual oil pressure guage would be nice as well.
