1992 F250 Engine Shaking
Old Sep 21, 2009 | 12:23 PM
rickscott2's Avatar
rickscott2
Hello all, I am new to this site and have a question. I have a 92 F250 7.3 and the engine shakes terribly until I hit about 50mph. Anyone have any clue what could be causing this?
Old Sep 21, 2009 | 02:16 PM
David85's Avatar
David85
Welcome to the forum, Rick.
We need some more info on your situation before we can really tell you what might be happening.
What transmission?
what gear are you in? (does it behave differently in different gears?)
Does engine RPM affect it at all?
How does the engine start and idle?
How old is your injection system?
Any smoke? (under what conditions?)
How many miles on the truck/engine/transmission
Old Sep 21, 2009 | 02:49 PM
joe f350's Avatar
joe f350
i think i coulb be a bad motor mount
Old Sep 22, 2009 | 08:47 PM
Dave Sponaugle's Avatar
Dave Sponaugle
All the crap I have done with my truck, loads, power, broken transfer case, many twisted driveshafts and on an on and my motor mounts are still original at 450,000 miles.
I am not saying they can't be broken, but it won't be easy to do.
rickscott2,
Welcome to FTE and the IDI diesel forum.
I also say we need a bit more info about your truck.
Old Sep 23, 2009 | 06:21 AM
mistakenID's Avatar
mistakenID
What about the shaking makes you believe it's the fault of the engine? Does it have a miss in the engine, rough idle, same vibration while sitting in neutral and raising the rpm or only shakes in gear and driving?
Old Sep 23, 2009 | 12:21 PM
PLC7.3's Avatar
PLC7.3
Could be a bad injector.......... or a DMFW flywheel....if a manual.
Old Sep 23, 2009 | 02:49 PM
rickscott2's Avatar
rickscott2
The trucks shakes while idling, and smoothes out when accelerating. After shifting it shakes until i hit around 45-50.
Old Sep 23, 2009 | 02:52 PM
rickscott2's Avatar
rickscott2
What transmission?
215,000 miles, Auto Tran, Don't know on injection system, It smokes (black) when first started and under load.
Old Sep 23, 2009 | 09:38 PM
Dave Sponaugle
Shaking while idling and at lower RPM's, I am going to guess injectors.
Old Dec 8, 2009 | 12:55 PM
rickscott2's Avatar
rickscott2
Thanks for the replies. I am replacing the injectors and when I pulled one of them out half of the injector is lodged in the port. anyone ever had this problem???
Old Dec 8, 2009 | 02:46 PM
wreckinball's Avatar
wreckinball
holy crap, i havent heard of that one before. so the top piece unscrewed from the bottom? Wow. you may want to put it back on if possible and first so a very small shot of pb blaster. Something to break it loose.
Old Dec 8, 2009 | 10:01 PM
S.P.'s Avatar
S.P.
Ok be fore going any further grind all the coarse threads off and locktight the fine threads, let set up 1 or 2 days, then put a 2x6- 2x10 over it, disable the injection system, crank and hope fully it pops out...
Old Dec 8, 2009 | 10:12 PM
S.P.'s Avatar
S.P.
Now if it doesn't pop out you will have to soak it with carbon blaster/berrymanns chem-tool or some such cleaner.
Scrape around the injector and try to pry it out and pull it out with a needle nose pliers.
I couldn't get mine to come out so I ended up pulling the heads and having them hot tanked,,The guy said it took longer to find the pliers then it took to pull it out...
So make sure you try to locktight the top part and crank it first, but don't damage the fine threads.... GOOD LUCK!!!
Old Dec 8, 2009 | 10:47 PM
wreckinball
would a heat gun be beneficial in this case? The hot tank just expanded the metals and broke things loose. Maybe a non flammable "carbon blaster" and some good heat? Just a thought.
Old Dec 9, 2009 | 08:46 PM
rickscott2's Avatar
rickscott2
SP,
I used locktite and screwed it back into the other half. I wont use needle nose pliers again, I am now missing a 1 inch chunk of skin off my knuckles using those things! So I should wait a day or two?
