Air Filter Housing
Old Sep 20, 2009 | 06:31 PM
desert sled's Avatar
desert sled
Air Filter Housing
Anyone have issues with dirty air getting past their air filters on their 7.3 PSD? I live in a very dusty part of the country and am off road frequently. I have checked my filter and found dust accumulating after the filter in the tube going to the turbo. I have repeatedly checked and cleaned this tube only to find dust. The tube is not broken, looks like a poor design. I am not real interested in a conversion because of all the hot air in the engine compartment. I have looked at the Ford AES filter but am not sure.
Old Sep 20, 2009 | 06:41 PM
WA.Ranger's Avatar
WA.Ranger
If I were you, and living where you do, I would look into a S&B.
http://www.riffraffdiesel.com/mm5/me...ode=F731-IN-SB
Old Sep 20, 2009 | 07:06 PM
binuya's Avatar
binuya
I got rid of my stock airbox for the same reason. Prone to warping and difficult to seal right. Vaseline on the rim of the filter can help but I didn't have any luck with that.
Old Sep 20, 2009 | 07:40 PM
Izzy351's Avatar
Izzy351
Look into the 6637. About a $30 filter, a piece of 4" OD exhaust pipe, a hose clamp, and you're set. Looks like this and breathes a TON of air:
Old Sep 20, 2009 | 08:08 PM
desert sled
Ive taped the seals of the airbox with black duct tape, I`m not sure about the 6637 mod because of all the hot air that is sucked into the engine,have you noticed any performance issues.
Old Sep 20, 2009 | 08:12 PM
Izzy351's Avatar
Izzy351
Yes, I've noticed performance "issues". My EGTs DROPPED. The "hot air" thing is a non-issue...
Old Sep 20, 2009 | 08:15 PM
jcrammell's Avatar
jcrammell
desertsled I have done a ton of research on air filters and housing / cold air intakes. I live in Arizona, like you very hot and dusty. The difference in the air temp is going to be minimal if at any. A lot of folks on this site run the 6637 and have had no problems with them. I just installed mine this weekend with a Pete's cover and man I can hear the difference. If you can afford it go with the S and B cold air intake. Excellent filter and intake but quite spendy. just my .02 though.
Old Sep 20, 2009 | 08:18 PM
zx250's Avatar
zx250
Of the next Riffraff East
Hot air not's nearly as bad as dust, and there's just no real data that proves the air difference is even there.
Old Sep 20, 2009 | 08:26 PM
binuya's Avatar
binuya
I personally, question the whole issue with the difference in underhood temperature air vs. ambient. Let's say you've got a 20-30F difference in underhood intake air on a 70F day. So your intake air temps are 90-100F.
Is this going to run differently or worse than a truck from Alaska in the winter on a -5F day? With underhood temps at 15-25F?
Surely if my thinking is flawed, someone will point it out, but there is so much hype and marketing around the 'cold air intake' concept I wonder about it's validity.
It's hard for me to think that trucks from colder climates run better than trucks from warmer ones.
Old Sep 20, 2009 | 08:33 PM
rbaker6336's Avatar
rbaker6336
If the open filter bothers you there is always the AIS which is a direct fit and has good filteration.Think mine was about $200
Old Sep 20, 2009 | 08:48 PM
desert sled
Ok, I am leaning toward the 6637 mod. What about keeping water out of the intake?
Old Sep 20, 2009 | 08:52 PM
Izzy351's Avatar
Izzy351
Just don't go over fender-well deep in water. Rain is a non-issue. I've been in some real down pours, and the filter remains dry.
Old Sep 20, 2009 | 09:00 PM
desert sled
Thanks to all for the responses.
Old Sep 20, 2009 | 09:07 PM
WA.Ranger's Avatar
WA.Ranger
X2! I monitored them a little and seen there wasn't enough of a differance to even bring it up again.
Here you go.
http://www.riffraffdiesel.com/mm5/me...e=F731-IN-6637
Old Sep 20, 2009 | 09:40 PM
desert sled
If I do a 6637 mod, will I need to monitor my EGT`s. The truck is completely stock.
