Sponsored by: Real Truck
Work Truck
Old Sep 20, 2009 | 02:53 PM
D-mon's Avatar
D-mon
Work Truck
I am not sure if i should put this here but anyway....
I am looking at my first diesel it would be used a work truck. It is a 1999 f-450 4x4, it has the 7.3 diesel with 83,000 miles. It also has a 10ft contractors box. This truck would be used to pull a trailer with a bobcat loaded on it, and then i guess rock or whatever in the bed.
Like i said it my first diesel what do i need to look for.
thanks guys!
Old Sep 20, 2009 | 07:19 PM
ford7379trucks's Avatar
ford7379trucks
no answers... well once you go diesel you'll never go back. just make sure everything works. GET A OASIS REPORT and a carfax. the oasis report you need to get from a Ford dealer. It will tell you what work has been done under warranty. helps find lemons.
Old Sep 20, 2009 | 07:28 PM
Firefighter 1406's Avatar
Firefighter 1406
Look for the condition of the engine bay. Excessive dirt accululating on the intercooler boots and pipes could mean lack of maintance. Check all the fluids, balljoints, and look at tire wear to see if any front end part is going out. I agree that once you go diesel you will never go back. 83,000 miles is nothing for these trucks. I bought my 99 with 167,000 miles on it and am at 213,000 miles with no problems. I had to replace the tranny at 200,000 but other then that no major problems. Just the regular maint, brakes, air filter, tires, and front wheel bearing. If you have a reputable diesel shop around you it might be worth the money to take it to them and have them do a good look over. I know this is not everything but I hope it points you in the right direction. Get the Oasis report mentioned, this will tell you what recalls and work done by the dealer from the truck being new.
Old Sep 20, 2009 | 07:48 PM
74baja's Avatar
74baja
You really should post this in the 7.3 forum. The guys there are awesome. Look in the 7.3 tech folder, I believe that's where the buying guide is.
Good luck
Old Sep 21, 2009 | 09:50 PM
D-mon's Avatar
D-mon
thanks guys
anyone else?
Old Feb 26, 2010 | 05:59 PM
D-mon's Avatar
D-mon
UPDATE ON THE WORK TRUCK
1999 F-450 V-10 4x4 with 94000
It has a 8' dump bed and a 2' or 16" tool box behind the cab.
Also has a boss V-plow
I think they are asking around $16500
That sound like a good truck guys, everything is pretty clean inside and outside.
ANy pro/cons about the v-10?
thanks!
Old Feb 26, 2010 | 06:26 PM
bill11012's Avatar
bill11012
Modular motor junkie
The V10 is great, but the 99 has less power than the newer ones.
Takes very little maintenance to keep it on the road a long time.
The only con is the fuel mileage in a truck that heavy will be crap.
Edit: and the exhaust manifold studs can break off, and they can spit plugs.
Price is kind of high.
Old Feb 27, 2010 | 12:11 PM
D-mon's Avatar
D-mon
The truck will not really be on the road that much so really gas mileage wont be to important.
So you think $16500 is kinda high??
They also said the truck was a STATE vehicle.
anyone else
thanks
Old Feb 27, 2010 | 12:28 PM
weyland426's Avatar
weyland426
State vehicle likely means it has spent ALOT of time idling...does it have an hour meter?
Old Feb 27, 2010 | 01:17 PM
bill11012's Avatar
bill11012
The truck is worth $8,000 in good shape, I don't know how much the the plow and dump bed add to it.
Have you looked around, is that what other trucks like it go for in your area?
Old Feb 27, 2010 | 04:20 PM
D-mon's Avatar
D-mon
Bill11012
i have been looking around for dump trucks in my area. the are usually asking around $15000 for a v10 4x4 and then Newer diesels 4x4 are going for around $20000 and up.
Just last week i test drove a 1998 3500 Dodge with a dump it was 4x4 and diesel and he was wanting i think $15000.
So I think its kinda a good deal for my area plus it has plow.
also where did you find out the price of 8000 if you dont mind telling me
thanks again!
Old Feb 27, 2010 | 04:48 PM
bill11012's Avatar
bill11012
thanks again!
No problem.
Thats about what the asking price is on most of the reg cab F450s I have seen around here.
I have never looked closely at one, just glanced as I'm driving by.
If thats what trucks go for where you live and it's what you need I would go for it.
Is it a 5 speed, 6 speed or an auto?
Old Feb 27, 2010 | 08:36 PM
D-mon's Avatar
D-mon
Yep well i will be talking to the bank here this week. so we will see.
And after you said it was a little HIGH i started looking around here on prices and yes its about the average for that kind of truck. Yes it will work for me. Might even keep it for a few years and then sell for newer ford diesel. The bed is the on the small size of what i want but i figured i can sell the tool box on it and the bed for a bigger dump but it should work out this way.
It is an AUTO
jamesobxfan2296
Nov 23, 2012 12:06 PM
Nice Work Truck
Feb 22, 2012 09:32 AM
screenburn
Jan 21, 2012 07:59 PM
gilend
Car/truck Buying Advice
Jul 17, 2011 06:01 PM
ibleedblueoval
Oct 14, 2007 10:01 PM
