powerstroke down!!
Old Sep 18, 2009 | 10:14 AM
clux's Avatar
clux
Originally Posted by Tenn01PSD350
Since we are not sure his filter is the culprit, we need to narrow it down some with the information we have. Since he has ICP codes it needs to be unplugged as suggested. See if it runs right then. If not, fuel system is a good next candidate.
That's good advice, but it doesn't sound like ICP symptoms to me, though. Both times I gelled, I did get the low/uncontrollable ICP codes. I'm sticking with the fuel supply theory, even though he should do the unplug test since it's so easy.
Originally Posted by 4inchlovin
Im going Negative on the CPS idea.... CPS issue dose not cause a truck to run poorly it just dies.
I recall the same thing being said about the #8 cylinder issue, couldn't be cause by a CPS.
Mostly just throwing some ideas out there, though.
Old Sep 18, 2009 | 12:48 PM
4inchlovin's Avatar
4inchlovin
A cylinder # 8 code being thrown seems to be a problem with the new cps. But i have never read anyone having a poor running issue and it turning out to be the CPS.
Old Sep 18, 2009 | 02:28 PM
stroker870's Avatar
stroker870
so do i have to wait till the truck does this again before i can unplug the sensor? cause it always happens when im goin down the road. and also my truck is taking longer to crank as well too
Old Sep 18, 2009 | 02:51 PM
MX_Fyrcaptain's Avatar
MX_Fyrcaptain
When my CPS went south it had the same symptoms. It would run poorly, then run fine until it finally died. But then again my fuel pump was also on it's way out.
Old Sep 18, 2009 | 03:24 PM
triskit16's Avatar
triskit16
You can check the ICP sensor at anytime. Start it, unplug the connector and see what she does. You will get a CEL from unplugging it.
cabloom300
19
May 2, 2014 03:27 PM
Jerry Chaney
Mar 19, 2014 01:02 PM
JMG1
Jun 8, 2013 12:22 PM
1duallyman
Jan 3, 2011 10:21 AM
Smokey1
Feb 14, 2010 11:05 AM
