Sponsored by: Real Truck
Electrical Problem
Old Sep 17, 2009 | 08:20 PM
jdboy's Avatar
jdboy
Question Electrical Problem
As the title implies I have a electrical gremlin! It's happened 4 or 5 times now and it goes away in a few minutes. After starting the truck or just turning the key on sometimes the radio and power windows have no power. So far they've began to work after a few minutes. Anyone ever experience this or have any idea what the problem is. An issue like this that sporadic and resolves itself can be nearly impossible to track down without an idea of where to look!! Any help would be appreciated!!<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Sep 17, 2009 | 11:12 PM
dstig1's Avatar
dstig1
I'd look at the door switches (esp drivers) and the accessory delay relay. Also start checking grounds. Take them apart, clean them and reassemble.
You are right, this will be a PITA to find...
Old Sep 18, 2009 | 06:51 PM
bayou barataria's Avatar
bayou barataria
I have seen a few people here that have had problems with the fuse box connectors, pull them off and check for corrosion and contacts.
Old Sep 18, 2009 | 08:42 PM
jdboy's Avatar
jdboy
Thanks’ for the heads up from both of the posts above. This is a very sporadic problem but I'm going to go through the fuse box and check for corrosion for sure. May even go ahead and replace appropriate fuses and relays since the cost wouldn't be very much as well.
Old Sep 18, 2009 | 10:11 PM
bayou barataria
If I remember right, some on here had problems behind the fuse box, you may have to pull and inspect it.
Old Sep 18, 2009 | 10:39 PM
dstig1's Avatar
dstig1
I think the leaky windshield seal was in the very early SDs 99-00 or thereabouts. But checking sure won't hurt and is easy enough.
Kart18
437
Mar 14, 2018 05:20 PM
Micbruff
23
Nov 5, 2014 08:17 PM
longcut13
Jun 13, 2012 03:54 PM
Mike821
Feb 16, 2011 10:20 AM
SBrown732
Apr 13, 2009 08:47 PM
