Transmission ?
Old Sep 17, 2009 | 11:26 AM
Brown Falcon's Avatar
Brown Falcon
Transmission ?
So all the 7.3's have the same transmission bolt pattern. Just curious, could you put a C6 auto behind a PSD?
I know it would suck not having overdrive... but for a offroad application would it work? I know that C6's are very strong and easy to build.
Would it hold up better than a E40D and would it even work without the electronics hooked up to a tranny?
Old Sep 17, 2009 | 11:59 AM
Talyn's Avatar
Talyn
C-6 is stronger the E4OD, but don't forget they run hot. Trans cooler necessary, specially with our power.
I dont know if the bolt pattern is the same though.
I know 460 has different bolt pattern, so I'd guess now.
Old Sep 17, 2009 | 01:59 PM
Brown Falcon
I know that the ZF5 from my '88 7.3 will fit on my '95 PSD
If I found one with a C6 it might fit.
Old Sep 17, 2009 | 08:43 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Ford sold Powerstokes with a C6 in 1995 and 1996. Neither year was high volume, but they were built. You MUST have one of the diesel C6s to be able to bolt it to a Powerstroke.
Old Sep 17, 2009 | 08:47 PM
IceboxFX's Avatar
IceboxFX
It must be from a diesel originally. Torque converter has more studs on it than a gas trans. I think it is 5 vs. 8.
Old Sep 18, 2009 | 06:42 AM
Brown Falcon
Hmm. I was just wondering... maybe for a project later on...
Old Sep 19, 2009 | 08:10 AM
deserthotrods's Avatar
deserthotrods
I have a '96 with the 7.3 how do I tell what tranny is in there ? It's actin' all goofy
Old Sep 19, 2009 | 09:02 AM
etldak's Avatar
etldak
Take a pic of the pan.
Old Sep 19, 2009 | 09:08 AM
MADVAN's Avatar
MADVAN
E4 is a electronic version of a C6 with extras!
I would opt for the E over the C anyday!
4 peed with a locking TC. It more like a 5 speed auto.
It does not compare to a c6 3 speed.
Bill
Old Sep 19, 2009 | 05:56 PM
Brown Falcon
I would be opting for strength instead of low RPMs cruising.
Old Sep 19, 2009 | 10:38 PM
MADVAN's Avatar
MADVAN
As far as strength goes they are about the same.
The C6 is a smaller lighter unit.
Comparison of the C6 and E4 in oem form. The E4 handles more torque input.
"ford spec". Yes the E4 has more parts that can break/wear. Its not an apples
to apples thing between the two.
Remember also that the the C6 is vac modulated. The psd has no vac.
Bill
