fuel consumption
Old Sep 18, 2009 | 11:15 PM
Dave Sponaugle's Avatar
Dave Sponaugle
100 km = 62.1 miles
16 liters = 4.16 gallons
62.1 / 4.16 = 14.92 MPG
That is not a bad figure for a 7000 pound 4x4 vehicle.
Old Sep 20, 2009 | 01:30 AM
Red Cobra's Avatar
Red Cobra
well i used to get 400 klm a tank now i see like 250klm and im blowing a tone of black smoke and it did not do that when i got the truck .. maybe im not boosting enough i only see about 5lbs max on my gauge..
Old Sep 20, 2009 | 08:41 AM
dakotajeep's Avatar
dakotajeep
I get mid 14's all the time......oversized mud tures tend to do that. I got 16ish when I have conventional treads tires......
Old Sep 20, 2009 | 09:47 PM
Dave Sponaugle
Black smoke is fuel you are only getting part of the work out of.
Wider tires catch more air and roll harder, lower MPG.
Anything that raises the truck up makes it catch more air, lower MPG.
Taller tires induce speedo error, the odometer shows less miles than you actually covered, apparent lower MPG than it actually is.
As for more black smoke than you used to see, have you changed anything?
Injectors getting weak causes them to pop early, advances the timing which can cause more black smoke.
How many miles on them?
Have you changed the air filter recently?
How long since the fuel filter was changed?
How many miles on the IP?
Old Sep 21, 2009 | 11:56 PM
Red Cobra's Avatar
Red Cobra
well i would have to say that because i noticed it get harder on fuel on a 13 hour or so drive to where im living now is there anyway that i could be burning more fuel because im way more north from where i was living??
but also i have changed a few things after a while of living here like i put a k&n air filter on but have run it without the filter to see if that was a problem
went from a bfg m/t to a way more meaty micky thompson m/t
now a straight pipe
no idea on how long they or the pump has been in the truck for the pump has a sticker on it and a diesel shop said it looked like it has had something done to it but i have owned the truck for about 9 or 10 months now and fuel filter was changed a few months ago but will put a new one on when i get the new injecters in
Old Sep 22, 2009 | 09:04 PM
Dave Sponaugle
The only thing being farther north that should affect fuel MPG would be more warm up time.
What kind of temps are you seeing at night?
Another thought would be the fuel blend if night time temps are close to freezing.
As temps drop, the fuel suppliers start blending #1 diesel or kerosene with the #2 to lower the chances of fuel gelling.
DIYMechanic
47
May 9, 2012 11:57 PM
povar
Alternative Fuels, Hybrids & Mileage
May 13, 2009 05:33 AM
sExplorer1524
Apr 17, 2003 03:12 PM
nbartey
Jan 30, 2002 06:46 PM
rob1024
1997 - 2003 F150
Nov 7, 2001 02:36 PM
