1978 - 1996 Big Bronco
1990 bronco
Old Sep 17, 2009 | 12:12 AM
bmacky14's Avatar
bmacky14
1990 bronco
hey i just bought my first ford bronco all it needs is a new exhaust system any ideas and i cant figure out how to open the rear door ?
Old Sep 17, 2009 | 03:16 PM
greystreak92's Avatar
greystreak92
Check out Bassani Exhaust. It's a little pricey but you will never worry about it again. As for the tailgate, roll the rear window all the way down. (Switch on the dashboard or the keyswitch in the gate) Inside at the top center of the gate is a release handle. Reach in and pull up on it. Gate should drop as long as the rear window is all the way down. (Don't think I need to mention this but, if you have an external tire carrier, you will need to open it first.)
Old Sep 17, 2009 | 04:27 PM
bmacky14's Avatar
bmacky14
alright thanks but my rear window wont go down i donno why
Old Sep 17, 2009 | 05:01 PM
g_k50's Avatar
g_k50
There's an access panel on the inside of the tailgate. Take that off and spray some lubricant on the hinge points of the window. Lubricate the weatherstriping with some silicone spray. have someone operate the window with the key in the tailgate while you try to lower the window by hand from the access panel opening.
New exhaust? Use your trusted local parts dealer.
Old Sep 17, 2009 | 05:20 PM
andym's Avatar
andym
If the tailgate isn't shut all the way the window won't move. Give it a good shove on both sides and then try it.
Old Sep 17, 2009 | 07:04 PM
g_k50's Avatar
g_k50
I have a 1990 Bronco and I don't think it has the safety lock on the tailgate closed.
I've lowered the window while the tailgate was open.
Old Sep 17, 2009 | 07:08 PM
andym's Avatar
andym
I have a 1990 Bronco and it has the safety mechanism. If you are able to move the window when it's open then someone bypassed the safety.
Old Sep 18, 2009 | 01:31 AM
g_k50's Avatar
g_k50
I stand corrected. The tailgate latches are required to be closed to operate the window. I remember having to close those with the tailgate down in order to raise the window.
Old Sep 18, 2009 | 03:18 PM
1Aauto's Avatar
1Aauto
Former Vendor
If non of the other solutions work,you may need to see if the motor has power with a test light.
Can you hear it click or anything?
Old Sep 19, 2009 | 08:58 PM
bmacky14's Avatar
bmacky14
still wont do nuttin and cant hear any motor or anything i donno. what does the switch beside the rear window switch do?
Old Sep 21, 2009 | 11:24 AM
andym's Avatar
andym
That's the defroster.
You're going to have to open the access panel and see what's going on inside.
Old Sep 21, 2009 | 12:22 PM
fordbroncodave's Avatar
fordbroncodave
get someone to hold the switch on the dash for you and see if its drawing battery power (look at the battery light on the dash and see if it goes towards the low side).
if it does that, take the access panel off and hit the motor with a hammer lightly while someone is holding the switch on the dash.
or you can take the electrical plug off the motor and put battery power to it. then try reversing the wires. if that doesn't do it, you probably have a bad motor or its rusted solid somewhere.
Ford Bronco Man
15
Jun 3, 2011 11:19 AM
mdr617
Bronco II
20
Mar 17, 2011 11:01 AM
Tonka1
New Member Introductions
Jan 3, 2010 03:43 PM
69BRONCO
1966 - 1977 Early Broncos
Aug 15, 2001 06:39 PM
henri
Jun 6, 2001 05:44 PM
