Wally World Oils
Wally World Oils
Stole this off of a Marine sight. Thought that it contained some interesting info re WW's oils.
I don't know how accurate it is or how often WW changes suppliers.
Rog
TECH 2000 SUPER CONCENTRATED FUEL INJECTOR CLEANER -- FIRST BRAND
SUPER TECH GAS LINE ANTI-FREEZE -- CRISTY
SUPER TECH R&O ANTI-WEAR OIL ALL GRADES -- SPECIALTY OIL
SUPER TECH RV WINTERIZER -- QUAKER STATE
SUPER TECH UNIVERSAL PRECISE MIX 2-CYCLE ENGINE OIL -- SPECIALTY
SUPER TECH SUPER CONCENTRATED FUEL INJECTOR CLEANER -- FIRST BRANDS
SUPER TECH GAS TREATMENT -- FIRST BRANDS
SUPER TECH FUEL INJECTOR AND CARBURETOR CLEANER -- FIRST BRANDS
SUPER TECH & TECH 2000 WINTER FORMULA -25 WINDSHIELD WASHER FLUID
SUPER TECH & TECH 2000 WINDSHIELD WASH -30F -- SOUTH WIN LTD</a><br>
SUPER TECH & TECH 2000 -20 WINDSHIELD WASHER FLUID -- SOUTHWIN T
TECH 2000 & SUPER TECH SUMMER FORMULA WINDSHIELD WASHER FLUID --S
SUPER TECH R&O ANTI-WEAR HYDRAULIC OIL ISO 46 -- WARREN DISTRIBUTOR
SUPER TECH BAR AND CHAIN OIL SAE 30 -- WARREN DISTRIBUTION
SUPER TECH UNIVERSAL HYDRAULIC TRANSMISSION FLUID -- WARREN DISTR
SUPER TECH MINERAL GEAR OIL SAE 90 -- WARREN DISTRIBUTION
SUPER TECH SAE 15W40 -- WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 20W50 OIL -- WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 5W30 MOTOR OIL -- WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 GENUINE 30W MOTOR OIL -- WARREN DISTRIBUTOR
SUPER TECH AND TECH 2000 30W MOTOR OIL -- WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 DEXRON III/MERCON AUTOMATIC TRANSMISSION
SUPER TECH AND TECH 2000 TYPE F AUTOMATIC TRANSMISSION FLUID --
SUPER TECH SAE 30 UNIVERSAL MOTOR OIL -- WARREN DISTRIBUTION
SUPER TECH 5W30 FULL SYNTHETIC OIL -- WARREN DISTRIBUTION
SUPER TECH FULL SYNTHETIC SAE 10W30 -- WARREN DISTRIBUTION
SUPER TECH SYNTHETIC BLEND SAE 5W30 MOTOR OIL -- WARREN DISTRIBUT
SUPER TECH SYNTHETIC BLEND SAE 10W30 MOTOR OIL -- WARREN DISTRIBU
SUPER TECH ENGINE TREATMENT -- SPECIALTY OIL CO
SUPER TECH STARTING FLUID -- VALVOLINE
SUPER TECH 50/50 ANTIFREEZE AND COOLANT -- OLD WORLD INDUSTRIES
SUPER TECH TILT AND TRIM FLUID -- WARREN DISTRIBUTION
SUPER TECH MULTI-VEHICLE AUTOMATIC TRANSMISSION FLUID -- WARREN D
SUPER TECH SYNTHETIC BLEND 10W40 MOTOR OIL -- WARREN DISTRIBUTION
SUPER TECH UNIVERSAL 2-CYCLE OIL -- WARREN DISTRIBUTION
SUPER TECH RV AND MARINE ANTI-FREEZE -- FOX PACKAGING CO
SUPER TECH ENGINE DEGREASER -- HYDROSOL INC
SUPER TECH CARB CLEANER -- HYDROSOL INC
SUPER TECH WHITE GREASE -- HYDROSOL INC.
SUPER TECH MULTI PURPOSE LITHIUM GREASE -- WARREN DISTRIBUTION
SUPER TECH MULTI DUTY COMPLEX GREASE -- WARREN DISTRIBUTION
SUPER TECH MOLY LITHIUM GREASE -- WARREN DISTRIBUTION
SUPER TECH MARINE GREASE -- WARREN DISTRIBUTION
SUPER TECH 0 DEGREE WINDSHIELD WASHER FLUID -- SOUTHWIN LTD
SUPER TECH AUTOMATIC TRANSMISSION FLUID -- WARREN DISTRIBUTION
SUPER TECH 75W140 SYNTHETIC GEAR OIL -- WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 GL-5 SAE 80W90 GEAR OIL -- WARREN DIST
SUPER TECH AND TECH 2000 GL-5 85W140 GEAR OIL -- WARREN DISTRIBUT
SUPER TECH FULL SYNTHETIC - ALL GRADES -- SPECIALTY OIL / PENNZO
SUPER TECH OUTBOARD 2 CYCLE ENGINE OIL TC-W3 -- SPECIALTY OIL
SUPER TECH MINERAL GEAR OIL SAE 90 -- SPECIALTY OIL / PENNZOIL QU
SUPER TECH AND TECH 2000 10W30 MOTOR OIL -- WARREN DISTRIBUTION
SUPER TECH SYNTHETIC BLEND MOTOR OIL - ALL GRADES -- SPECIALTY O
SUPER TECH SUMMER WINDSHIELD WASH (WASHER FLUID 32) -- FOX PACK
SUPER TECH +22 F WINDSHIELD WASHER FLUID -- FOX PACKAGING
SUPER TECH 10W40 -- EXXON MOBIL
SUPER TECH 20W50 -- EXXON MOBIL
SUPER TECH R AND O ANTI WEAR HYDRAULIC OIL AW 46 -- SPECIALTY
SUPER TECH SAE 30 UNIVERSAL MOTOR OIL -- PENNZOIL QUAKER STATE
SUPER TECH AND TECH 2000 WINDSHIELD WASHER FLUID -25F -- FOX PA
SUPER TECH WINDSHIELD WASHER FLUID -20F -- FOX PACKAGING
SUPER TECH MARINE OUTBOARD 2 CYCLE ENGINE OIL TC-W3 -- SPECIALT
SUPER TECH MARINE HIGH VISCOSITY 80W90 LOWER UNIT GEAR LUBRICANT
SUPER TECH CORROSION CONTROL AND TRAILER WHEEL BEARING GREASE --
SUPER TECH CONCENTRATED FUEL INJECTOR CLEANER -- PENNZOIL QUAKER
SUPER TECH GAS TREATMENT -- PENNZOIL QUAKER STATE
SUPER TECH POWER STEERING FLUID -- PENNZOIL QUAKER STATE
SUPER TECH HIGH PERFORMANCE BRAKE FLUID DOT 3 -- PENNZOIL QUAKER
SUPER TECH UNIVERSAL 2 CYCLE ENGINE OIL -- PENNZOIL QUAKER STATE
SUPER TECH 80W90 AND 85W140 GEAR LUBRICANT -- SPECIALTY OIL
SUPER TECH MARINE POWER TRIM AND TILT FLUID -- PENNZOIL QUAKER
SUPER TECH SAE 30 UNIVERSAL HEAVY DUTY DIESEL ENGINE OIL -- PE
SUPER TECH PERFORMANCE ENGINEERED HD SAE MOTOR OIL - ALL GRADES
SUPER TECH HEAVY DUTY TRACTOR HYDRAULIC AND TRANSMISSION OIL -- SPEC
SUPER TECH R&O ANTI WEAR HYDRAULIC OIL AW 46 -- SPECIALTY OIL
SUPER TECH FUEL INJECTOR AND CARBURETOR CLEANER -- SPECIALTY OI
SUPER TECH TYPE F AUTOMATIC TRANSMISSION FLUID -- SPECIALTY OIL
SUPER TECH DEXRON III / MERCON AUTOMATIC TRANSMISSION FLUID -- SPEC
SUPER TECH BAR & CHAIN OIL GRADE 30 -- SPECIALTY OIL / PENNZOIL
SUPER TECH SAE 15W40 UNIVERSAL MOTOR OIL -- SPECIALTY OIL / PENN
SUPER TECH PERFORMANCE ENGINEERED MOTOR OIL - ALL GRADES -- SPECI
SUPER TECH ANTIFREEZE / COOLANT -- HONEYWELL
SUPER TECH WINDSHIELD WASHER PREMIUM DEICER -30 -- FOX PACKAGIN
SUPER TECH 5W30 -- EXXON MOBIL
SUPER TECH MULTI LUBE -- HYDROSOL
SUPER TECH OIL TREATMENT -- NATIONAL INTERCHEM LLC
SUPER TECH 10W30 -- EXXON MOBIL
SUPER TECH HD 30 -- EXXON MOBIL
Rog
