Sponsored by: Real Truck
Walmart Super Tech Oil
Old Apr 15, 2009 | 01:47 PM
Firefighter 1406's Avatar
Firefighter 1406
I was wondering if anybody has used walmart super tech oil. Is it as good as other name brands or not. I was wondering because I can get the rear diff. fluid for about 5 dollars cheaper a qt.
Old Apr 15, 2009 | 02:43 PM
SBastow's Avatar
SBastow
I always go back to the old saying "you get what you pay for" I would stick with Motorcraft or your brand of choice.
Old Apr 15, 2009 | 02:48 PM
PERFORMANCE RED's Avatar
PERFORMANCE RED
If you change often I wouldn't see a problem with it but if you like some miles on your oil and filters I would use a better brand. All oils must meet the requirements of the government and manufactures so I am sure it would work.
Old Apr 15, 2009 | 02:58 PM
juneau76's Avatar
juneau76
I've used it in the past (not on this truck) because it's cheap and it's oil. It used to be made by Shell, but I think someone else makes it now. I'm not sure about yours, but my rear diff requires synthetic and limited slip additive. You may want to check on that if you haven't already done so.
Old Apr 15, 2009 | 03:07 PM
03_PSD's Avatar
03_PSD
thats what i was thinking Brad, syn. oil only.
Old Apr 15, 2009 | 06:39 PM
Firefighter 1406
My walmart in town sells a full syn. 75-140 gear lube. It is $10.56 a quart. I just went to the dealer and got a price of $18 something a quart and I know valvoline at Advance is about $15 a qt. I already bought the additive from the dealer. I was just wondering what you guys thought about the syn. Super Tech 1000 and just adding the additive.
Old Apr 15, 2009 | 08:28 PM
motown's Avatar
motown
Their synthetic gear oil is suppose to be a good product. You can take a look at the website link below. The people on it are oil freaks, its a good source for oil info.
Bob Is The Oil Guy - Powered by Motor Oil
Old Apr 15, 2009 | 10:51 PM
LMS Residential's Avatar
LMS Residential
Just be sure the gear oil isn't imported from China like 90% of the rest of their product. Melamine and lead aren't known for their viscosity.
Old Apr 16, 2009 | 09:12 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
You get what you pay for....
The thought had crossed my mind to try it, but I love my truck a little too much to put something like that in it. My guess is that they don't put much r&d into their oil, thus it won't stand up to our engines for very long as a more expensive oil would.
If you have something just needs some oil in it, something that you don't plan on keeping for long or something like that, by all means go ahead. But with our engines expensive as they are, I would pay the extra money and know that my engine is getting oil that will stand up to it and not break down for atleast 5k miles.
Old Apr 16, 2009 | 10:04 AM
eightrac's Avatar
eightrac
The oil is produced by "Warren performance products" the makers of CAM2 lubricants. The super-tech full synthetic motor oil is essentially the same as "CAM2 super-synthetic".
Some people are saying "you get what you pay for" but in the end, this is truly a good oil. I have a ford escort that has over 200k on it now that has had nothing but super tech in it from day one. The engine is clean inside ( I had to replace a valve cover gasket and the oil pan a while back) and runs like it did with 50k miles on it.
The next thing they will say is that it has a "paraffin base" that is a bad lubricant for engines. Little do they know, thier Motorcraft semi-syn's and Mobil-1's also contain paraffin. AS ALL SYNTHETIC MOTOR OILS DO.
Old Apr 16, 2009 | 06:59 PM
Lou Braun's Avatar
Lou Braun
I use the SuperTech synthetic oil in my Subaru. Blackstone oil analyis test results show that it works as well as any other synthetic oil.
Too bad that they don't offer a diesel equivalent.
Lou Braun
Old Apr 17, 2009 | 01:44 PM
renoduckman's Avatar
renoduckman
oil
I have not used it it my F250 but used alot of it in my old Ranger. Truck has very high millage and still running well. Just for what that is worth.
Old Apr 17, 2009 | 06:57 PM
dkf's Avatar
dkf
If its meets the specs (which I believe it does) that the other major brand oils do, its fine.
mtgrzlyman
Jul 7, 2016 11:36 PM
comsupany
13
Apr 1, 2016 03:41 PM
Wrathfulram
1983 - 2012 Ranger & B-Series
Mar 30, 2015 08:53 PM
RA31925
General Automotive Discussion
Jul 19, 2013 05:39 PM
daddio360
Oil & Lubrication
40
Jul 3, 2008 11:00 AM
